It is currently Jul Sat 21, 2018 1:25 am
Post New Topic Post Reply  [ 34 posts ]  Go to page Previous  1, 2
 Post subject: Re: Three different 6888 & 6GY6 xmitt versions...
PostPosted: Nov Sun 12, 2017 2:09 pm
I've still got 6GY6 and 6888 tubes if anyone needs them.
KB3QNN 73
PostPosted: Nov Thu 16, 2017 9:25 pm
I'm going to give this transmitter a try. Not satisfied with the Lil7 transmitter. Did I hear of a kit available somewhere or just have to get all the parts separately? Either way, looks like a fun project to work on. At least I have a good handful of the parts on hand.
Jeff
PostPosted: Nov Fri 17, 2017 4:27 am
Bill Hamre did have a kit with parts, but after 10 years or so most of the interest in building was history... He did mention just prior to your post he has 6888 tubes...
PostPosted: Nov Fri 17, 2017 5:43 pm
Thank you Tom for clarifying. Just wanted to see if their was a kit before scouring around for all needed parts. Luckily I do have a handful of parts. I guess the challenge for me is locating a good matching coil or learning how to coil my own. But for now, I'll start with the power supply.
Jeff
PostPosted: Nov Sat 18, 2017 2:24 am
Jeff
I have a remainder of one of Bill's kits, plus a few coils on hand...
Lemme know what you need and I'll send the parts I have...
I dunno if UHF converters are still cheap on ebay, that's generally where I'd source my "project boxes"... They'll almost always have chassis, sockets & transformer needed... The Granco & Mallory are usually the best ones to use, no doubt are others...
PostPosted: Nov Sat 18, 2017 4:51 pm
Thank you Tom.
If you have most of the kit left, let me know how much you want for it. I either have or it is not hard to get all the capacitors and resistors, same with the diodes. Sockets, tubes and coils would be a great help. I've got plenty of jacks and have several 1 meg hertz crystals and I think I have a transformer that would work, it's a 120v in 125/12v out rated 15mA and 300mA. Do you think that would work? If wiring the tube filaments in series should divide the 12 volts to 6volts each? Or using a resistor of the appropriate value? Or is the Amperes ratings too small?
Let me know what you will part with and how much you want for them.
Jeff
PostPosted: Nov Sat 18, 2017 4:53 pm
Also I just posted the radio this will transmit too. As for a project box, I don't know exactly what I am going to do other than the whole enclosure will be in a wooden cabinet, hand made.
PostPosted: Nov Sat 18, 2017 5:32 pm
Your transformer has to low of current rating... Probably ought to have a 30-40ma rating on HV winding and a 6888 has a 800ma heater and 6C4 is 150ma, you'd want at least a 1A rating for that... For a some headroom 1.5A would be better... To series tube heaters the current must match, a 150ma tube in series with 800 would receive almost all the voltage...
BTW I assume you are building the 6C4 - 6888 version??
PostPosted: Nov Sat 18, 2017 5:57 pm
Yes, that is the one I am going to build. I had intended to mention that. I was afraid that rating would be too low for the transformer. Just spending a little time looking around, that value of transformer is tougher to find.
PostPosted: Nov Sat 18, 2017 6:48 pm
Jeff,
PM me with a mailing address and I'll send you a 6888.
Bill
KB3QNN 73
PostPosted: Nov Sun 19, 2017 12:29 am
Do you have tubes such as 6AV6 or 6AT6??
With different basing connections either can be used in place of 6C4... And give a increase gain...
PostPosted: Nov Sun 19, 2017 1:41 am
No, but i saw that the place where i get my capacitors and resistors has one for six and a half bucks, thats not too bad. Antique electronic supply.
PostPosted: Nov Sun 19, 2017 4:02 pm
Hang on, I can come up with the audio amp tube, no charge...
Got a box of some used ones, have to test to be sure it's good...
PostPosted: Nov Sun 19, 2017 4:33 pm
Ok, sounds good. I found a much less expensive transformer at old radio parts. It's more of a hassle to order their, but the prices and selection are superior. So it'll take a few days to get my order through. Also want some crystal radio items from him as well.
Jeff
