| Author |
reeves03
Post subject: Radiola 18 questions Posted: Aug Wed 08, 2012 4:17 am |
Joined: Jun Sat 18, 2011 3:36 am Posts: 631 Location: Milton, FL 32570
| Top |
battradio@
Post subject: Re: Radiola 18 questions Posted: Aug Wed 08, 2012 7:45 am |
| Member |
Joined: Jul Fri 18, 2008 10:02 am Posts: 1372 Location: near ST Louis Mo
The switch and tubes are easy to come buy in the radio classified forum . The tunning cap mostlikely can be realigned . The lamp hood is near imposible to find an oridgenal .
_________________ Mark
| Top |
Burnt Fingers
Post subject: Re: Radiola 18 questions Posted: Aug Wed 08, 2012 1:42 pm |
Joined: Oct Sat 20, 2007 3:36 am Posts: 13596 Location: New Hampshire
Im surprised it was still in use in 1939.
| Top |
Nick D.
Post subject: Re: Radiola 18 questions Posted: Aug Wed 08, 2012 3:20 pm |
| Member |
Joined: Jun Wed 01, 2011 9:05 am Posts: 6734 Location: "Amish Country", PA
Surprised? From what I've seen, the majority of these radios will have tubes dated into the mid or late 30's. Are you just as surprised at the people that are still hanging on to their 10+ year old CRT TVs?
_________________ Majestic - Crosley - Zenith ~CONSOLE FREAK~ Philco - American Bosch - RCA
| Top |
Alan Douglas
Post subject: Re: Radiola 18 questions Posted: Aug Wed 08, 2012 5:10 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 23519 Location: Pocasset, Cape Cod, MA
If all the tubes test bad, I'd wonder about the tester.
| Top |
Dale Saukerson
Post subject: Re: Radiola 18 questions Posted: Aug Wed 08, 2012 11:39 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6185 Location: Minneapolis, MN USA
I would deal with the tuning cap issue before all else. It's usually caused by pot metal expansion of the tuning drum (fatal) not gummy shafts or bent plates (simple). Supposedly the tuning drum issue can be dealt with but most folks experience heartbreak in their attempt. http://www.nostalgiaair.org/References/ ... la18-1.htm
| Top |
reeves03
Post subject: Re: Radiola 18 questions Posted: Aug Thu 09, 2012 12:06 am |
How easy or hard should it be to turn? Once I tightened the set screw it rotates but it's like always having had a car with power steering an going to a classic vehical with manual steering. It moves but nothing like the Hallicrafters s-38 I have. When I took chassis out, the pilot lite hood was in there  , it has two pins looks like it just pushes into the wood? The tubes marked bad were testing between 50-60 on a jackson 648r. jason
| Top |
Dale Saukerson
Post subject: Re: Radiola 18 questions Posted: Aug Thu 09, 2012 2:56 am |
I have touched three tuners.....One turned with somewhat more effort as that of most wooden antique radios that use a dial string. Two turned with more effort like dragging a knife thru a jar of peanut butter. If yours turns with one hand and doesn't want to turn you instead.....it's good enough!
The dial hood tabs fit thru the metal trim plate and fold behind it. The hood alone is worth $ 50.00 to some people.
Don't worry about the tube test results just yet. You have lots more major internal parts to confirm are working. Radiola 17s are cheap to buy---expensive to fix.
| Top |
reeves03
Post subject: Re: Radiola 18 questions Posted: Aug Thu 09, 2012 3:25 am |
Haven't plugged it in yet, but to be sure I should pull the tube power on with a dim bulb tester, if Transformer is good put in rectifier bulb and test voltage and then on down the line, correct?
But not having a speaker for this yet how should I address this?
Thanks, Jason
Also it was mentions this should be in elctro mechanical restoration instead of discussions, how do you move it ask a Mod?
| Top |
mcpherjc
Post subject: Re: Radiola 18 questions Posted: Aug Thu 09, 2012 8:50 am |
| Member |
Joined: Jun Sun 03, 2012 8:21 pm Posts: 541 Location: APO AP
There is a hood on ebay right now: http://www.ebay.com/itm/RCA-RADIOLA-18- ... 2320b9e906As mentioned these do not come up often so I wouldn't wait to long. I had to buy another whole Radiola 17 to get a hood for my 17. Your cabinet seems to be in good condition. There are some 27 and 80 tubes in the classified section for a resonable price right now as well.
_________________ Mac
Zenith Crosley GE Philco RCA
| Top |
Burnt Fingers
Post subject: Re: Radiola 18 questions Posted: Aug Thu 09, 2012 4:54 pm |
Quote: Surprised? From what I've seen, the majority of these radios will have tubes dated into the mid or late 30's. Are you just as surprised at the people that are still hanging on to their 10+ year old CRT TVs? Since youre still a teenager or close how many TRF radios have you actually seen and know the continuous history of? Anybody can put any date tube in a socket when selling and keep the good ones....thats a common stunt at radio meets, Fleabay, etc. Carl
| Top |
reeves03
Post subject: Re: Radiola 18 questions Posted: Aug Thu 09, 2012 4:58 pm |
I just thought it was neat as I had never seen bad stickers on tubes before and the raffle ticket was interesting also. Anyone know if the store chain still survived or not?
jason
| Top |
Alan Douglas
Post subject: Re: Radiola 18 questions Posted: Aug Thu 09, 2012 5:16 pm |
The stickers were put on when the tubes were tested but the owner didn't want to spring for new ones. The shop would hope for a future sale. The tubes may not have been quite as bad as the shop wanted the owner to think they were. He may have opted to replace only one.
The raffle ticket is unique but is three years too early for that set, so must have been for a different one. Still worth displaying with the set.
| Top |
reeves03
Post subject: Re: Radiola 18 questions Posted: Aug Fri 10, 2012 6:46 am |
The tubes w stickers tested about 50 to 60. On a jackson 648r. Still in red range. But somewhere I read these tubes were not pushed hard by the circuit so bad tubes might possibly still work in this radio.
What other things should I check before Power up on a dim bulb tester? All wires look to be in good shape. No components look burned.
Thanks. Jason
| Top |
Nick D.
Post subject: Re: Radiola 18 questions Posted: Aug Fri 10, 2012 6:55 am |
| Member |
Burnt Fingers wrote: Quote: Surprised? From what I've seen, the majority of these radios will have tubes dated into the mid or late 30's. Are you just as surprised at the people that are still hanging on to their 10+ year old CRT TVs? Since youre still a teenager or close how many TRF radios have you actually seen and know the continuous history of? Anybody can put any date tube in a socket when selling and keep the good ones....thats a common stunt at radio meets, Fleabay, etc. Carl I haven't seen tons, but I can still extrapolate: These sets came just before the Depression, so it would be plenty logical to assume many of these sets were kept and used years after they were bought. These also weren't the throwaway days of "It's 5 years old... ancient! Let's toss it, honey."
| Top |
Burnt Fingers
Post subject: Re: Radiola 18 questions Posted: Aug Fri 10, 2012 3:27 pm |
Quote: I haven't seen tons, but I can still extrapolate: Translation: ASS U ME with minimal input. Quote: These sets came just before the Depression, so it would be plenty logical to assume many of these sets were kept and used years after they were bought. These also weren't the throwaway days of "It's 5 years old... ancient! Let's toss it, honey." However the discussion is about 1939 tubes. The Radiola 18 was 11 years old then, has poor selectivity in ever more crowded frequency space, the BCB allotment has changed, and the poor audio remains the same. The Depression was almost over, auto sales were high, manufacturing was gearing up for war material for the UK and others and the cost of a small table radio was at an all time low. I cant picture many except the elderly and the very poor hanging on and/or tolerating one that long. By 40-41 many were buying a new radio as well as vehicles knowing that war was certain and production would cease for the duration. I use mine very sparingly and just to listen to a ballgame in order to keep it exercised and can tolerate the audio enough to turn up for the good parts. There are many much better sounding TRF's. Carl
| Top |
mcpherjc
Post subject: Re: Radiola 18 questions Posted: Aug Thu 16, 2012 4:00 am |
| Member |
Just to let you know another member StrombergMike has a Radiola 18 dial light hood for sale. You can PM him to work out the details. Good Luck.
| Top |
tubeAMP
Post subject: Re: Radiola 18 questions Posted: Aug Fri 17, 2012 2:13 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2756 Location: Gainesville, Florida
those old triodes are usually good if they have filament continuity. if the filament is good the tube is usually as good as it gets PS: maybe this guy can help unles you are building a museum piece http://www.radiolaguy.com/RadiolaLampHood.htm
_________________ CAUTION: Im no expert
| Top |
reeves03
Post subject: Re: Radiola 18 questions Posted: Aug Fri 17, 2012 3:20 am |
When I opened it and took chassis out the hood fell out. So I just need to get a on/off switch and some free time.  jason
| Top |
mcpherjc
Post subject: Re: Radiola 18 questions Posted: Aug Fri 17, 2012 3:35 am |
| Member |
reeves03 wrote: When I opened it and took chassis out the hood fell out. So I just need to get a on/off switch and some free time.  jason You have no idea how lucky that was!
| Top |
Users browsing this forum: No registered users and 5 guests |
