It is currently Jan Sat 19, 2019 2:49 am
 Post subject: Toggle switch rating Q ...
PostPosted: Sep Sat 08, 2018 9:04 pm
hi friends,
toggle switch on my old Fairchild 412 is bad ... it's a Und Lab 3A 250v / 6A 125V w/ an extended 1" neck (turntable's base is very thick) i found another switch w/ ball tip, 1" neck but it's rated 3A 125v /1A 250v
is this an adequate substitution?
thanks in advance,
mike
 Post subject: Re: Toggle switch rating Q ...
PostPosted: Sep Sat 08, 2018 10:37 pm
Is the toggle switch really bad? I have cleaned thousands of them and brought 95% back to life. Just dribble several drops of Deoxit down past the toggle (with the switch upright) and actuate the switch about a hundred times.
PostPosted: Sep Sat 08, 2018 11:08 pm
ha ok ..
maybe not but terminal broke, leaving nothing to solder to ... case of switch is riveted together w <tiny> rivets.
easier for me to get another.
will the new value mentioned initially, work?
thanks, johnny,
mike
PostPosted: Sep Sun 09, 2018 1:13 am
I would be inclined to say no because its current rating is significantly less than the original, but to be sure you would need to know how much current there was through the original.
PostPosted: Sep Mon 10, 2018 12:52 am
I really don't think a turntable motor would draw more than an amp. Running current can be measured easily enough, or you could measure the DC resistance of the winding to determine the maximum inrush current.
PostPosted: Sep Tue 11, 2018 12:38 am
thank you, fellas
tough finding a suitable toggle w/ such a long neck .. replacement should be here by weekend, i'll report back.
tom, my instincts are you're correct ; )
best,
mike
PostPosted: Sep Thu 13, 2018 7:12 am
replacement toggle working fine ...
even <before> replacing switch, when i toggle fairchild on or off, i'm getting a very loud POP ... any suggestions where to look for this issue?
thank you, all
mike
PostPosted: Sep Fri 14, 2018 12:19 am
Maybe try putting a capacitor across the switch contacts?
Unemployed Analog Meter Technician. Simpson 260 specialist.
John, KK6WHY
PostPosted: Sep Fri 14, 2018 12:33 am
I just purchased 2 of these with the same ratings as above. ACE Hardware sells these. I ordered from an online dealer a couple of months ago. I don't recall offhand who. If you want, PM me and I will try to lookup where I got them.
PostPosted: Sep Fri 14, 2018 3:23 pm
0.1 or 0.047 uF cap in series with 100 Ohm resistor across the switch contacts should kill the pop - these are available as a single component - search for "snubber". Cap alone may do the job.
PostPosted: Sep Sat 15, 2018 1:11 am
thank you, fellas
scott, toggle i received seems to be working fine.
tom, cwr, .047 alone did the trick!
thanks again all,
mike
PostPosted: Sep Sat 15, 2018 5:46 am
Good. Make sure to use an X rated safety capacitor.
John, KK6WHY
PostPosted: Sep Sat 15, 2018 2:19 pm
i've got a .047 400v orange drop in there ..
that ok?
TU!
m
PostPosted: Sep Sun 16, 2018 8:50 am
Negative. I would categorize a capacitor across a power switch in the same category of one across the power line. When the switch is open, the full line voltage appears across the capacitor.
See here:
https://www.justradios.com/safetytips.html
And Here:
https://www.allaboutcircuits.com/techni ... apacitors/
John, KK6WHY
PostPosted: Sep Mon 17, 2018 7:06 pm
So what if the capacitor should short out? The motor will run -- no damage. But because of the inductive spike when the motor is switched off the capacitor needs a very high working voltage. The usual capacitor used in this application is a ceramic disc rated at 1 or 2kV.
-David
PostPosted: Sep Fri 21, 2018 12:50 pm
just reading this, fellas, thanks
m
