It is currently Jan Sat 19, 2019 3:57 am
 Post subject: Before I put the covers back on...
PostPosted: Nov Fri 09, 2018 2:07 am
My Grommes 24pg amp (daily driver) blew it's fuse last night. I never even saw the pilot light light. The fuse was blown violently. So, of course I tried another fuse. As my mother would have said "Sam Tink"... the fuse blew real good.
Today I put it on the bench, and approached it with the full arsenal of variac, dim bulb, and amprobe (with the fuse holder jumpered). It came up fine. I checked it with the output tubes out, then added them channel by channel, swapped them around. Checked bias / voltage, and ran music threw it. Wiggled and twisted the line cord, and the wires coming out of the transformer. Dropped it an inch onto the bench. It's now running fine. I had a good look in case the upper and/or lower covers could be shorting something. Can't see a thing.
So, before I put the covers back on, can anyone think of something I missed? The blown fuses were 2.5 amp. I see that it wants a 3 amp fuse which I will get tomorrow. I'm wondering whether an intermittent filament short could have been the trouble, or something else weird that I might have missed.
All ideas welcome.
David
PS it was re-capped about five years ago, and got new tube sockets at the time. It's been running on that 2.5 amp fuse since then, almost daily.
 Post subject: Re: Before I put the covers back on...
PostPosted: Nov Fri 09, 2018 2:53 am
David, SloBlo fuse or just a regular fast-acting fuse?
PostPosted: Nov Fri 09, 2018 2:57 am
See how many watts it draws from the outlet. Monitor that while using, if it creeps up, filter caps are going bad.
PostPosted: Nov Fri 09, 2018 3:06 am
Kill-A-Watt is great for monitoring currend at the outlet.
PostPosted: Nov Fri 09, 2018 2:13 pm
Fast acting fuses. It blew two in a row, then on the bench was fine. It draws about an amp, spikes to almost two at turn on, cold filaments I presume. It uses a pair of indirectly heated rectifiers (ez80), so the b+ takes several seconds to build up. The fuses blew instantly.
I thought maybe a short in the line cord at he strain-relief or something with the two convenience outlets, but that's all before the fuse. Still stumped.
David
PostPosted: Nov Fri 09, 2018 3:26 pm
Since they blew instantly when cold, we know it's not heat related.
Since they didn't blow on the bench with it opened up, we know it's not a [permanently] internally shorted component.
Definitely sounds like a shorting condition, mechanical in nature.
You might try gently tapping on the tubes to check for intermittent internal trouble.
If it blows again with covers back on, and you haven't moved anything inside, you'll know for sure whether the covers are forcing a short.
Maybe recheck your work on those new sockets.
PostPosted: Nov Fri 09, 2018 4:36 pm
I tapped and wiggled everything including the tubes, but it just occurred to me that the first thing I did at the bench was to turn it upside down to remove the bottom cover. Has anyone ever had a tube where debris inside caused a short? That said, I have cured one or two crt shorts by smacking the tube facing down on the table, but those were inter-electrode shorts that weren't fuse-blowers.
PostPosted: Nov Sat 10, 2018 2:00 am
Yes, I have seen a few tubes that had loose parts inside that shorted out when put in to the right orientation. I never figured out whether or not it was because debris was built into it, or part of it came apart after aassembly. In one case, it was the former, because there was an entire loose mount inside it.
Brett
Users browsing this forum: micajah and 4 guests
