It is currently Apr Fri 27, 2018 7:31 am
 Post subject: Schematic for unknown(?) RCA MI-38618A amp?
PostPosted: Jun Fri 17, 2011 3:10 am
I'm trying to help identify this for a friend...he sent me these photos:
tag says "mi-38618A s/n C1885"
Rubber stamped on chassis is 102661. Tube lineup is 6SL7 6SL7 6V6 6V6 5Y3
Anyone point me to a schematic for this guy, more info, etc.? Is the model MI-38618A? Grille Cloth DBs list a couple of Matco amps, but not any RCA, with this tube line-up.
I could really use a schematic (edited for clarity.)
 Post subject: Re: Help identify an unknown RCA PA amp?
PostPosted: Jun Fri 17, 2011 3:46 am
you have a model number, the MI number and a brand. how much more ID do you need?
im not following what your after?
PostPosted: Jun Fri 17, 2011 3:48 am
Er, a schematic? I can't find one anywhere. Been searching every place I know to look.
 Post subject: Re: Schematic for unknown(?) RCA MI-38618A amp?
PostPosted: Jun Sat 18, 2011 3:02 am
It's going to be pretty simple. One 6SL7 is the microphone preamp, the other 6SL7 is the voltage amplifier/phase inverter, the two 6V6s are push-pull outputs, and the 5Y3 is the full-wave rectifier. You can probably find a very similar schematic in a mid-1950s RCA tube manual circuits section.
-David
PostPosted: Jun Sat 18, 2011 3:39 am
Actually tubes are 5y3gt
6sl7gt
6sj7
6v6gt
6v6gt
I was wondering if anyone had a rough estimate on the year. And what does MI correspond to inthe model number?
Jason
PostPosted: Jun Sat 18, 2011 5:06 am
If the unit is complete and unmolested, you could probaby get by without a schematic; these were not difficult to work on.
William
PostPosted: Jun Sat 18, 2011 5:20 am
Many of RCA's amplifiers started with MI; I don't know what it means.
I checked Riders PA manual and it's not there; or in Sams.
PostPosted: Jun Sat 18, 2011 6:30 am
id guesstimate your amp is from the early to mid 50's. you can rebuild it without a schematic. replace one part at a time. replace all the caps. take macro pictures before you start work as it will help you figure stuff out if you get in a bind.
PostPosted: Jun Sat 18, 2011 1:55 pm
RCA commercial equipment, including theatre and broadcast stuff, was all identified with the "MI" numbers,which stood for "Master Item". That equipment was covered in RCA's own service/instruction literature, which was in loose-leaf form. A copy, containing schematic, pictorial, and parts list, was included with each unit.
A few, but not many, MI-numbered amplifiers got covered in Rider's and Sams.
PostPosted: Jun Sun 19, 2011 4:43 am
6sl7gt
6sj7
6v6gt
6v6gt
Jason
In that case the 6SJ7 (a pentode) is the microphone pre-amplifier and the 6SL7 is the voltage amplifier/phase inverter. The microphone input goes to the grid of the 6SJ7 (perhaps via a potentiometer) and the phono input probably goes to one of the grids of the 6SL7 (maybe via a potentiometer, likely not).
The MI number is the model number on RCA commercial equipment (not RCA Victor).
-David
PostPosted: Jun Sun 19, 2011 4:51 am
Cool appreciate all the info. I was just hoping for a schematic just like I look for a map before I go somewhere new.
Thanksfor all the help.
jason
PostPosted: Jun Sun 19, 2011 5:00 am
I know this may be old hat to many of you, but I'm trying to break into this. And was wondering if anyone has any tips or reference to drawing out circuits by looking at the chassis wiring. Forgive me if this sounds dumb but I think it'll help me understand more of what I'm doing.
thanks,
jason
PostPosted: Jun Wed 22, 2011 1:56 am
When "reverse engineering" something I usually start with the active elements....tubes...transistors. Get the pin out for the tube. Find each component from there. Then from there you can trace out the power supply.
For example lets say you identify a tube's plate load resistor. Most of the time the other end of that is going to wind up at a power supply voltage.
Work slowly and carefully and make your drawing. It doesn't have to be that neat yet.
Stop when you get tired or frustrated and come back to it later.
PostPosted: Jun Wed 29, 2011 4:14 pm
I would like to replace the multistage capacitor can on this amp(individual caps are fine).
Here is the info on the cap can
CDE
DD0185A
30 to 40 MFD 500 W.V. with half moon identifier
30 to 40 MFD 500 W.V. with square identifier
15 to 20 MFD 500 W.V with triangle identifier
15 to 20 MFD 500 W.V with no identifier
UPN 10690
to replace this I would assume getting 2 x 47uf 500v and 2 x 22uf 500v caps and wire them in or should I get a lower value? Final usage would hopefully be a guitar amplifier.
Under chassis I have 2 x 50 MFD 50 WVDC and 2 x 10 MFD 25WVDC
can I replace these with 47uf 50v and 10uf 25v?
thanks,
Jason
PostPosted: Jun Wed 29, 2011 4:18 pm
Those substitutions all seem pretty reasonable to me, that's exactly what I'd do if I were repairing it.
PostPosted: Jun Wed 29, 2011 6:26 pm
CDE
DD0185A
UPN 10690
thanks,
Jason
I dunno, that stinkin' little 3uf difference might be an issue.... it seems that tiny amounts of difference of capacitance cause lots of confusion on here.
Amateur tinkerers simply don''t know how to round things off and call it a day.
PostPosted: Jun Wed 29, 2011 8:26 pm
What about the multi-stage being listed as 30-40MFD and 15-20MFD?
Is this just a funny way of saying its tolerance factor?
Jason
PostPosted: Jun Thu 30, 2011 1:06 am
Tube - equipment is very tolerable and forgiving when it comes to tolerances.
PostPosted: Jun Thu 30, 2011 1:24 am
Maybe so but the question is still there.
jason
PostPosted: Jul Sat 02, 2011 4:00 pm
To answer your question, electrolytic capacitors made 50 years ago had a pretty large variance from the nominal value 20% more or less was common. Therefore the range rather than nominal value was sometimes stamped on the parts. They all drift up in value and leak after decades, or short, or become completly open and should be replaced. Plus 20% or minus 10% is close enough for any audio application. I would use 450 VDC electrolytics and 630 VDC mylar caps in all cases just so I don't have to keep so many different parts on hand. Always OK to use higher rated parts.
While you at it, you could check the carbon resistors, and you will find most of them have drifted way up. So cheap and easy to replace them while you have the set apart, and can make a big difference in performance.
