It is currently May Thu 23, 2013 5:27 pm
 Post subject: Sherwood S-7000
PostPosted: Dec Fri 02, 2011 4:14 pm
Could anyone give me the tube layout for this set? Or perhaps the schematic? It's in Sams
folder 586 number 12, which I don't have.
many thanks
 Post subject: Re: Sherwood S-7000
PostPosted: Dec Fri 02, 2011 7:29 pm
Hopefully you have the output tubes. 7591A's are not cheap. Don't have a schematic for you but they are available.
Hopefully a mod will move this to the audio section. You will get more help there.
PostPosted: Dec Sat 03, 2011 12:48 am
I think that my S-7000 (AM/FM version) uses 7868s.
Vigorously Supporting the First Amendment
PostPosted: Dec Sat 03, 2011 5:57 pm
Either way a set of output tubes will be costlly, so I'd check out the transformers, etc... before making a lrge commitment on glass.
PostPosted: Dec Sat 03, 2011 8:08 pm
It is the best sounding tube amp I have ever had, beter than the Fisher I have (also 7868s).
If you choose not to fix it, I would not mind having another.
Russ
Users browsing this forum: bobwilson1977, Moontan and 2 guests
