It is currently May Wed 22, 2013 4:25 am
 Post subject: Dynaco FM3
PostPosted: Apr Wed 11, 2012 7:08 am
Will the FM3 work without a functioning tuning eye? I wish I could find an EMM-801 for a reasonable price.
 Post subject: Re: Dynaco FM3
PostPosted: Apr Wed 11, 2012 2:26 pm
Assuming that I remember the FM-3 schematic properly, the eye tube is solely used as an indicator. One beam (lower) is for tuning and the upper one for stereo indication. You can always leave a "dead eye" tube in place. It just won't look quite as cool. 8) I normally tune "eyeless" FM receivers by ear. The high frequencies get clearest at proper tuning. Expect some minor drift as the unit reaches normal operating temperature.
Info here: http://www.triodeel.com/schindex.htm
PostPosted: Apr Thu 12, 2012 6:00 pm
If you go to "www.the-planet.org" you can find instructions on replacing the EMM801 with an EM84, which has only a single display. You'll lose the stereo indicator, but you'll have the tuning indicator. It's a fairly simple rework, a few wire changes at the socket.
PostPosted: Apr Fri 13, 2012 4:52 pm
Could make a plug in adapter with wiring running toan external box then use an EM 84 and also wire up a circuit to use a neon bulb for the stereo indicator or a second EM84.
PostPosted: Apr Sun 15, 2012 11:47 am
Try to find a donor "parts set" FM3 for a reasonable price, say, $50 - $60, it will include all the tubes and unobtanium components to keep your tuner in good order.
