It is currently May Sat 18, 2013 1:11 pm
 Post subject: Technics SP-15 with SME 3009 arm
PostPosted: Apr Fri 20, 2012 11:11 pm
I have a Technics SP-15 with an Audio-Technica arm, and it works well. However, I was just given a nice used SME 3009/Series 2 "improved" arm, and I would like to use it on this turntable. Has anyone here set one up this way, and will I need to order the auxiliary spacer to raise the arm?
Note to the moderators: Feel free to move this to the phonograph forum, if it may fit better there.
 Post subject: Re: Technics SP-15 with SME 3009 arm
PostPosted: Apr Sat 21, 2012 2:58 am
I have a friend who has this set-up. I understand that his SME arm is a limited-production 10" version which can play 16" transcriptions. He uses a Stanton 681EEE cartridge with it. He made the plinth from kitchen chopping block stock. I believe his arm had enough range in it's height adjustment so as not to need a spacer but his turntable is actually sunk down into the plinth a bit.
Users browsing this forum: Ron Pond and 2 guests
