It is currently May Sat 25, 2013 5:16 pm
 Post subject: Kenwood kc 206 remote issue
PostPosted: May Tue 01, 2012 7:12 pm
After trying unsuccessfully several times and admittedly getting quite frustrated I cranked the volume on a late 80's stereo wondering why on earth I had no volume...low and behold I felt more than a little stupid to discover that the remote volume on the unit was turned way down...my newfound happiness was short lived as the remote is nowhere to be found...so finally the question...after speaking with a less than confident salesman at the usual big name joint...will modern universal remotes work such an old unit? a friend at work speaks highly of the harmony 650 but again unsure if a modern remote will do the trick...any advice will be greatly appreciated. thank you. :)
 Post subject: Re: Kenwood kc 206 remote issue
PostPosted: May Tue 01, 2012 8:32 pm
I doubt it. That model was brought out before the world of universal remotes so they probably won't work with the MPU in the amp. You can try, they are cheap enough. Too bad the original remote is no longer available.
Jim
"AC volts and DC volts and little lamps and lities..."
PostPosted: May Tue 01, 2012 9:09 pm
This may not work, but, here you go,http://www.newremotecontrol.com/Mfrs/Kenwood/Kenwood.htm.
PostPosted: May Wed 02, 2012 10:18 pm
Thank you both for the replies. Great site for info!
an original is on it's way and will be guarded much better in the coming years.
thanks again. :)
