Page 1 of 1
[ 7 posts ] |
| Author |
Bill1956
Post subject: McIntosh 40 Posted: Aug Sun 05, 2012 8:50 am |
The filter caps under the chassis are rated 500 volts. My replacements are rated 450. Can I get away with placing in line a surge preventing resistor to accomodate the lower rating?
thank-you
| Top |
Pbpix
Post subject: Re: McIntosh 40 Posted: Aug Sun 05, 2012 9:08 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 9188 Location: Haledon, NJ, usa
I don't think so. Adding a resistor will reduce surge impact on initial charge... but unless it's a really large value (voltage-dropping) resistor it will not in anyway limit the exposure the caps see at maximum voltage.
I'd use the 500volt rated caps.. esp since line voltages today are 10 - 15 volts more than they used to be.. driving up the voltage on the 2ndary of your power transformer feeding the rectifier.
_________________ " To be a man, Be a non-conformist, Nothing is as sacred as integrity of your own mind." Emerson
| Top |
Bill1956
Post subject: Re: McIntosh 40 Posted: Aug Mon 06, 2012 4:22 am |
thanks, Peter. I'll put the 450v rated filter caps aside. Any idea where I can find ones rated at 500?
| Top |
battradio@
Post subject: Re: McIntosh 40 Posted: Aug Mon 06, 2012 4:33 am |
| Member |
Joined: Jul Fri 18, 2008 10:02 am Posts: 1372 Location: near ST Louis Mo
_________________ Mark
| Top |
Pbpix
Post subject: Re: McIntosh 40 Posted: Aug Mon 06, 2012 6:47 am |
| Member |
Bill1956 wrote: thanks, Peter. I'll put the 450v rated filter caps aside. Any idea where I can find ones rated at 500? http://www.amplifiedparts.com/products/ ... EC40-20-20
| Top |
Tom Bavis
Post subject: Re: McIntosh 40 Posted: Aug Tue 07, 2012 2:29 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3856 Location: Rochester NY USA
| Top |
Bill1956
Post subject: Re: McIntosh 40 Posted: Aug Tue 07, 2012 3:21 am |
thank-you, Mark, Peter, and Tom for helping me out.
| Top |
Page 1 of 1
[ 7 posts ] |
Users browsing this forum: No registered users and 1 guest |
