It is currently Apr Wed 25, 2018 1:46 pm
 Post subject: Thermal Cutoffs for QSC A41 Power Amplifier
PostPosted: Jan Wed 11, 2017 11:32 pm
I am currently working on a QSC A41 Power amplifier that has some shorted transistors.
The unit is from 1980. The transistors have a date code of 52 week of 79.
The output wattage is 330 watts per channel.
I have found the transistors, but I am also in need of the Thermostats that are attached to the lower heat sink.
They are marked on the back Elmwood Sensors model 2450. Which I believe is now a Honeywell 2450 and solder type T101.
Then they have the following numbers stamped on them.
The 1st sensor has 88-257 L185 79/F
The 2nd sensor has 88-261 F130 79/G
What I need to know is what is the cut off temperature are these thermostats.
One works but the other one is open.
I tried heating the working one with a heat gun and measured the cut off temperature at around 100 degrees F., which I am thinking is a little low.
Any Help would be greatly appreciated.
Pics are included
Jason
Tube Glow and Tube Sound, Awesome!
 Post subject: Re: Thermal Cutoffs for QSC A41 Power Amplifier
PostPosted: Jan Sat 14, 2017 7:29 pm
http://www.ebay.com/itm/HAFLER-DH-500-D ... yAjw3AXsuw
70 degrees C if normal or 160 F
Mark
