It is currently Jul Sun 22, 2018 3:56 am
 Post subject: Lafayette LR-1500T weak channel?
PostPosted: Nov Sun 26, 2017 7:18 pm
Hi all,
I just picked-up a really nice Lafayette LR-1500T in a wood case and although it sounds great with the balance set in the middle, when you move the balance to the left the audio disappears and when you move it to the right the audio screams way more than normal, put it back in the middle and both channels sound great......is this a cap or transistor issue?
Cheers, Steve
Sometimes discussing the wrong path leads you down the right one.....
 Post subject: Re: Lafayette LR-1500T weak channel?
PostPosted: Nov Sun 26, 2017 8:04 pm
More info required:
What position is the Mode switch in?
What position is the Selector switch in? (What are you using for a signal source?)
Is the Tape Monitor switch in the Off position?
Using left & right speakers or stereo headphones?
Is Loudness switch Off?
PostPosted: Nov Sun 26, 2017 10:17 pm
manualman wrote:
More info required:
What position is the Mode switch in?= Stereo
What position is the Selector switch in? (What are you using for a signal source?)- Aux with an iPhone......same symptoms in FM mode
Is the Tape Monitor switch in the Off position?= Yes
Using left & right speakers or stereo headphones?= Speakers
Is Loudness switch Off?= Yes
Cheers, Steve
PostPosted: Nov Mon 27, 2017 12:32 am
Since you're trying to determine left and right channel functionality, I would only use one input at a time. Put a signal into the left channel only; with some volume setting, rotate balance control from center to left and then to right. Audio should only appear from balance center to left extreme. Now do the same test with the input in the right channel. With some volume setting, rotate balance control from center to right and then to left. Audio should only appear from balance center to right extreme. If you don't hear audio, or it's distorted, in a channel, then that channel has a problem. Note that distortion can also be generated by too high of an input signal so be aware of that too.
PostPosted: Nov Tue 28, 2017 12:19 am
Thank you for your input but I was trying to find out that if a channel is "over active" wether it was normally a cap or transistor issue.....
Cheers, Steve
PostPosted: Nov Tue 28, 2017 12:26 am
If a channel truly has excessive gain the cause is usually an open capacitor in a negative feedback network. It would not be a transistor.
-David
PostPosted: Nov Tue 28, 2017 3:54 pm
-David
Thanks!
Cheers, Steve
