It is currently Jun Wed 19, 2013 7:04 pm
Post New Topic Post Reply  [ 51 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Sony TC-630
PostPosted: Apr Thu 12, 2012 9:33 pm
In my experience the worse the cap the slower the motor up to and including not running at all. IOW, losing torque and being overcome by friction.
Might as well go through all the mechanics, eh? I mean, that was a LONG time ago.
PostPosted: Apr Fri 13, 2012 4:49 pm
Yes replace the motor capacitor. A good going through the mechanics will be beneficial. Clean all the old grease off everything that has grease on it then apply new grease. WOuld be best to get a service manual before doing any dissasembly. Also should consider replacing the electrolytic capacitors on all the PC boards.
PostPosted: Apr Thu 19, 2012 7:20 am
I just picked up a Sony TC 630. not in the best of shape. The speakers are missing as is the speed select knob.
I picked this up just to transfer some late 60's communication tapes between my parents and I to modern media. And they are on 1-7/8 speed.
I downloaded a PDF service manual from hifiengine.com but most of the diagrams of where to oil etc are too black to read.
Anyway after removing and relubing the wheels etc it turns out that the horizontal spring that engages a wheel to the capstan and flywheel is weak. at 1-7/8 Everything seems to work if I put some extra tension on this spring. I am wondering if anyone has new springs or should I just take a couple of rounds up on this one. I should say that at 7-1/2 speed everything stops rotating except the motor and capstan unless I put a LOT of tension on that spring.
PostPosted: Apr Thu 19, 2012 7:23 am
Replace the idler wheel - it's not the spring.
PostPosted: Apr Thu 19, 2012 11:29 am
Idler wheel. Need to either replace it or try this stuff http://www.reelprosoundguys.com/RestoreKit.html
PostPosted: Apr Thu 19, 2012 7:45 pm
ok, anyone got a idler wheel?
PostPosted: Apr Thu 19, 2012 8:09 pm
If your idler wheel has no cracks in the rubber try the stuff I mentioned first and see if that helps any unless of course someone has a good idler wheel.
PostPosted: Apr Fri 20, 2012 9:12 pm
Ok, not trying to start a argument here but
How soft of rubber are these wheels supposed to be. I'm guessing there are no very new wheels available.
And when the unit is in 1-7/8 speed the spring is just hanging there, there is no tension on the idler wheel.
And the capstan is knurled for the faster two speeds but smooth for the 1-7/8 speed.
PostPosted: Apr Sat 21, 2012 12:58 am
Dis-assembly and cleaning is in order to correct issues due to 40 year old grease.
Replacement rubber is in order if 40 year old drives slip.
Otherwise, a thread with 4,000 posts ensues.
PostPosted: Apr Sat 21, 2012 4:57 am
LOL
Thanks, I have cleaned and relubed most of the moving parts including all the wheels.
In this area nothing is hanging up anymore. Chunks of hardened lube fell out of some of the springs.
This wheel is hard, not cracked but you can't leave a fingernail imprint in it.
PostPosted: Apr Sat 21, 2012 7:07 pm
so I found a replacement pinch roller kit and a belt replacement kit. hopefully these fix the problem. I will also try to clean and re grease it. Any suggestions on the brand of grease to use? I'll have to figure out the caps when I crack it open.
thanks G
