It is currently Apr Sun 30, 2017 7:46 pm
 Post subject: WTB green cloth speaker wire
PostPosted: Apr Fri 21, 2017 12:24 pm
Hi folks, I am looking for some green cloth covered speaker wire (tinsel type) to make my own cord. Radio Daze sells the brown color which I have used in the past, but they do not have green.
One particular cord that I want to make will need pins on both ends which is not so common. Phoneco sells one that would be usable, but first I will see if the wire alone is available.
Russ
A place for everything, everything in it's place. I just don't remeber where all those places are.
 Post subject: Re: WTB green cloth speaker wire
PostPosted: Apr Fri 21, 2017 1:50 pm
Try here;by the foot or the roll.
http://vintagewireandsupply.com/round-c ... ered-wire/
Doug
Do sober what you said you'd do drunk. That will teach you to keep your mouth shut.
PostPosted: Apr Sat 22, 2017 1:53 pm
Also try here might be able to get some more stuff you need at the same time ;)
https://www.tubesandmore.com/products/wire-hook-lacquered-spool
PostPosted: Apr Sat 22, 2017 3:05 pm
I just got some wire from Tube Depot and was very pleased. One of the things I liked having used several other cloth covered wire is that the cloth does not fray when you strip the ends. Very easy to work with. You can buy single colors and in small quantities at very cheap shipping rates. They also have it in 18 ga.
https://tubedepot.com/products/20-ga-stranded-cloth-wire-600-volt-rating
Rick
AB5ON
Forest Gumping through life
PostPosted: Apr Sat 22, 2017 3:31 pm
Tinsel wire is much more flexible than those.
This vendor claims to have a very flexible headphone cord in many colors. I assume these are 3 conductor. Ad doesn't say tinsel wound, doesn't say what material, but the price may be low enough to take a chance?
http://www.ebay.com/itm/2017-3-5mm-Stereo-Jack-To-Jack-Audio-Headphone-Aux-Cable-Sound-Lead-Wire-Cord-TR-/152327304899?var=451544430983&hash=item23776a36c3:g:WZoAAOSwL7VWmc2k
-Richard Fairbanks
PostPosted: Apr Sat 22, 2017 6:02 pm
https://sites.google.com/site/jackpiner ... ords/cords
It is real tinsel cord, green appears to be available.
GL
There Are None So Blind As Those Who Will Not See: John Heywood, 1546
Post New Topic Post Reply  [ 6 posts ]  Moderator: Philco Fan
Users browsing this forum: BrianU, edison64, gizmojeff, Jim Dutridge, Lou deGonzague, Luddite, Ron Ramirez, studioguy and 7 guests
