It is currently Oct Sat 20, 2018 1:36 am
 Post subject: FS: 50 Ohm Dummy Loads 5/10/25/50 Watt
PostPosted: Dec Thu 07, 2017 11:10 pm
I have a bunch of 50 Ohm dummy loads for sale. Shipping extra, from Norfolk, 23518. PayPal (F&F), claim and PM me your address for the total.
Prices and quantities available:
5 Watt Shively Labs - (1) available, $5
5 Watt Dielectric/Gen Signal (5) available, $5 each
10 Watt Dielectric/Gen Signal (5) available, $8 each
Thanks for looking!
Thanks for looking!
Brian
 Post subject: Re: FS: 50 Ohm Dummy Loads 5/10/25/50 Watt
PostPosted: Dec Fri 08, 2017 12:08 am
Greetings,
I'll take one each of these:
5 Watt Dielectric/Gen Signal (7) available, $5 each
10 Watt Dielectric/Gen Signal (7) available, $8 each
PM to follow.
Thanks, Terry
"Hardware eventually fails. Software eventually works" - Michael Hartung
PostPosted: Dec Fri 08, 2017 1:11 am
What's the frequency range on the 50-watt Bird?
- Leigh
73 de W3NLB
http://www.AtwaterKent.info
PostPosted: Dec Fri 08, 2017 1:14 am
I'll take the 50W bird if Leigh passes.
Last edited by 4thDoctorWhoFan on Dec Fri 08, 2017 1:22 am, edited 1 time in total.
PostPosted: Dec Fri 08, 2017 1:18 am
- Leigh
Per the datasheet, DC-3.5 Ghz, with VSWR of 1:1.1 guaranteed to 1 Ghz. Upper is limited by the QC-N connector Bird uses on all their stuff.
Brian
PostPosted: Dec Fri 08, 2017 1:30 am
Findm-Keepm wrote:
...guaranteed to 1 Ghz. Upper is limited by the QC-N connector Bird uses on all their stuff.
But modern N connectors are good to at least 11 GHz.
- Leigh
73 de W3NLB
PostPosted: Dec Fri 08, 2017 2:20 am
- Leigh
Bird used QC interchangeable connectors on nearly all their wattmeters and loads. You can buy them with traditional connectors too, but Bird wanted folks to have interchangeable connectors so that N-male could become a UHF Female with just a 4-screw swap. One guy has a business built on Bird stuff: http://www.nm3e.com/prod04a.htm - you can get a feeling of just how versatile their stuff is.
Me, nothing above 2.1Ghz with any appreciable power, so 11Ghz wouldn't be possible (unless I was merely measuring the freq with my 5351B counter with a munged faceplate.... :?
Brian
PostPosted: Dec Fri 08, 2017 3:50 pm
I'll take the 25 watt.
AA5LP
PostPosted: Dec Sun 10, 2017 1:02 pm
terryrh wrote:
Greetings,
PM to follow.
Thanks, Terry
Terry,
Still want them?
Brian
PostPosted: Dec Sun 10, 2017 5:30 pm
Yes-- I tried to send a PM but must have messed it up. PM on the way (I hope)!
Terry
PostPosted: Dec Sun 10, 2017 5:51 pm
I'll take a 10-Watt Dielectric, please.
PM coming.
Rodney -- KG7EPW
 Post subject: Re: FS: 50 Ohm Dummy Loads 5/10 Watt
PostPosted: Dec Mon 18, 2017 1:22 am
Bump. Only 5 and 10 watt types available.
Brian
Post New Topic Post Reply  [ 12 posts ]  Moderator: Philco Fan
Users browsing this forum: Als_Basement, gkaczowka, Merrill Bancroft, Skip, Waterski and 20 guests
