It is currently Jun Mon 18, 2018 6:31 pm
 Post subject: FS RCA BP-10 Portable **SOLD**
PostPosted: Feb Thu 17, 2011 5:01 pm
I have a RCA BP10 portable Radio for sale.
It has a few issues:
Bottom plate missing leatherette insert. You might choose to recover the whole unit.
Leather case needs to be reassembled (stitched back together
and 1/2 the carry strap reconstructed.)
Corrosion on top of A battery clip. Glass beading should clean it up.
Fair + to Good - overall condition.
I have a scan I can email of the original instruction sheet.
$55.00 plus shipping from 06357. (NOW $40.00)
(Worse case USPS Medium Flat Rate)
PostPosted: Feb Fri 25, 2011 11:44 am
Bump
PostPosted: Apr Thu 14, 2011 2:48 am
still available
PostPosted: Apr Thu 14, 2011 3:22 am
Might have more interest if you mention this was the first popular radio to use miniature tubes.
http://www.nostalgiaair.org/PagesByMode ... 015428.pdf
Also in Beitmans 1941.
PostPosted: May Tue 03, 2011 6:37 pm
grid-leak wrote:
still available
The Antique Radio Classified had a good article on this radio in the February 2011 issue. :)
PostPosted: May Wed 04, 2011 12:10 am
Recapping the BP-10 is a snap, and it is delightful to play. You can string 9v batteries in series, and they'll fit in the case easily. This radio is earlier than most people think; mine has a date of 1939 stamped on the inside tag. Also, redoing the leatherette was a snap.
Could be a fun project for someone.
PostPosted: May Wed 04, 2011 12:18 pm
Good video tour of one here:
http://www.youtube.com/watch?v=OSJzdxDr96Y
Glenn
PostPosted: May Wed 04, 2011 11:15 pm
Could you post a photo of your BP-10 as well as the inside tag? RCA started selling the BP-10 to the public in June of 1940. But, a few were supposedly sold at the 1939 Worlds Fair. I've seen a lot on eBay with 1940 date stamps, but never 1939. Thanks.... :)
PostPosted: May Wed 04, 2011 11:17 pm
Uh Oh. Now that you mention it, it may be 1941. I'll take a look when I get back Friday, and post the tag.
PostPosted: May Thu 05, 2011 12:42 am
I had problems trying to get one of my BP-10's to track properly. It didn't work at all until it was re-capped and all but two resistors were WAY out of tolerance. Tubes were OEM and were fine. Suffice to say I peaked it so it had good sensitivity overall despite not matching the dial markings. Yes, I tried the padder capacitor, up/down in value, even the IF coils, still no change in dial accuracy.
The antenna tabs are a SOB too. I used brass shim to repair them. Many BP-10's have a busted door. Broken door were such a problem the repair part number made it to Riders...
Chas.
PostPosted: May Fri 06, 2011 3:31 am
My Bad, stamp is 1940. I'm happy to email larger res scans to anyone...
Last edited by SmoothOscillator on May Fri 06, 2011 11:37 am, edited 1 time in total.
PostPosted: May Fri 06, 2011 3:40 am
SmoothOscillator, PM sent. Scotty.
PostPosted: May Fri 06, 2011 4:35 pm
I started a data base on the BP-10 about a year ago. So far I have about 80 entries. The earliest date stamp is August 28, 1940 with serial number 043085. If anyone has an earlier dated BP-10 I'd like to know. :)
 Post subject: Re: FS RCA BP-10 Portable
PostPosted: Mar Mon 19, 2012 1:08 am
forgot I still have this.
Price now $40.00..
The case has to be worth half that much...........
 Post subject: Re:
PostPosted: Mar Tue 20, 2012 4:22 pm
Can you scan in the tag? I've never seen a BP-10 with a date earlier than August 1940. :P
PostPosted: Mar Tue 20, 2012 7:11 pm
Scanner not working at the moment.
Oct 1940 to answer you.
Post New Topic Post Reply  [ 16 posts ]  Moderator: Philco Fan
Users browsing this forum: Greg Dan and 8 guests
