Folks, basement clean-out
. Sold to first in line as per forum guideline. Pls PM me for info.
1) Transistor checker. $6+ USPS ship. I don't know if it works, and a little dusty. I did open it to check the battery holder. No battery, holder condition is Spotless. 1 clip-on lead is missing.
2) Scope CRTs Used. $3 each + ship. (or $5 for both + ship)
Long one - 3WP1 has burn in. Could not figure out which pins are filament, if you know I'd be happy to check continuity.
Short one - could not find a number. Filament continuity, but base is loose so you may have to resolder pins. Some burn in as shown.
3) Vintage Fanon Walkie Talkies. T808 5Watts. $8 both + ship. Comes with Photofacts. These have plenty of marks, name etched in, they are rough-fair cond. Both antennas work, but one has a plastic cap on top. I recall the battery containers were clean, but had loose contacts. At one point I think I had reception on one on a channel. Heavy. I'm not sure about the crystals. Requires lots of AA batteries.
4)
*Sold* Transformer. $7 + ship. I used this for years thinking it was an isolation transformer only to find out that the 1-hand rule probably saved my life more than a thousand times
NO ISOLATION. I don't know what it is. Has outlet below the nameplate, not pictured. Again,
NO Isolation.
