It is currently May Sat 25, 2013 2:17 am
Forum rules
 Post subject: WTB : audio interstage xformer for RCA R11 chassis
PostPosted: Apr Fri 06, 2012 5:23 am
Hi. I need an audio interstage transformer that drives two type 47 output tubes in an RCA R11 chassis. The center-tap on the secondary of mine is open. The RCA part number is 7271. If anyone knows of a replacement part, please let me know.
Thanks.
 Post subject: Re: WTB : audio interstage xformer for RCA R11 chassis
PostPosted: Apr Sun 08, 2012 10:51 pm
A pic would help. I probably have something similar.
If the coil has continuity across the ends:
1. You have a good coil with a broken wire or bad solder joint from the center of it. Most likely at the point where the small xformer wires connect to a larger interconnect wire or maybe at the terminal solder joint.
2. Give the resistance reading across the coil. That would make it easier to ID a replacement.
3. This one works good enough in other sets.
http://www.hammondmfg.com/radiola1.htm
PostPosted: Apr Sun 15, 2012 10:57 pm
I checked the coil resistance. The primary measured 2.5k ohms and the secondary measured 4k.
Does anyone think it likely one of the replacements from AES would work?
In this circuit, a type 27 drives two type 47's.
Thanks.
PostPosted: Apr Sun 15, 2012 11:34 pm
FYI, Hammond 118944 is 4000T to 6000T/6000T. It will give a 1/2.25 impedance ratio.
Edit - it sounds like yours has a good secondary winding and the connection to the center tap terminal is broken. This is a good candidate for explorative surgery. You may well be able to fix it.
PostPosted: Apr Sun 15, 2012 11:43 pm
It's potted in tar inside of a can and would be a bit messy.
Thanks for the info.
PostPosted: Apr Sun 15, 2012 11:52 pm
What about the PT-156 under Hammond ?
PostPosted: Apr Mon 16, 2012 1:36 pm
Freeze the coil and carefully chip the potting out around the center tap wire.
Post New Topic Post Reply  [ 7 posts ]  Moderators: John Bartley, Philco Fan
Users browsing this forum: LarryW, shovelhead and 7 guests
