It is currently May Sat 25, 2013 10:56 am
Forum rules
 Post subject: WTB: B-5991 Nixie with round grid supports
PostPosted: Apr Tue 17, 2012 1:49 am
I am trying to restore an HP 3440A digital multimeter. Unfortunately, one of the nixie tubes is cracked from corrosion of one of the pins. I am looking for a replacement that will match the others, so if anyone has a B-5991 nixie which has little round washers visible from the front of the tube at the ends of the grid support wires (as opposed to the newer ones which are square) I would be interested in buying it.
Thanks!
-Matthew
If it ain't broken, you’re not trying hard enough...
 Post subject: Re: WTB: B-5991 Nixie with round grid supports
PostPosted: Apr Tue 17, 2012 2:49 am
A National (brand) 8422/5991 will be a direct replacement. I have four NOS but that's just enough to build a clock. If nobody offers one up in a day or two, send a PM to me. After all, the meter is a worthy cause too. I have one. It gets some attention at work when I use it. 8)
PostPosted: Apr Tue 17, 2012 3:06 pm
I have an H-P boxed part 1970-0009. The former owner has written 8422 on the box. I didn't pull it out but I can see it has round washers on the face. No idea what these things go for but I'm definitely open to an offer.
PostPosted: Apr Tue 17, 2012 3:26 pm
Thanks Alan! :D Check you PM.
-Matthew
PostPosted: Apr Tue 17, 2012 4:11 pm
Here is one: http://www.ebay.com/itm/Vintage-Burroug ... 27b7b49fe3
Dale
http://www.dalesantiqueradio.com/
PostPosted: Apr Tue 17, 2012 6:44 pm
Thanks Dale, but that one has the square grid supports.
-Matthew
PostPosted: Apr Tue 17, 2012 6:51 pm
Found! Thanks all.
-Matthew
Post New Topic Post Reply  [ 7 posts ]  Moderators: John Bartley, Philco Fan
