It is currently May Thu 23, 2013 5:27 pm
Forum rules
 Post subject: HP 204C audio generator (sold)
PostPosted: Apr Fri 27, 2012 4:45 am
HP 204C Audio Signal Generator provides 5Hz to 1.2MHz in 6 ranges. Output: >5V open circuit, 2.5V into 600ohm. Distortion: 0.1%. Haven’t used much but test showed it working well. Appearance wise it is only in fair condition with engraving on the front and top. It also has the remains of magic marker on the sides and top that would probably clean off. $25.00 plus 8 pounds shipping from 45601. Edit:sold
SENCORE PR57 AC POWERITE variable isolation transformer. This transformer is in very good condition both cosmetically and electronically. It serves as both an isolation transformer and variable transformer. 0 - 3amps continuous and up to 4 amps intermittent, 0 – 140 Volt output. $100.00 plus 22 lbs. shipping from 45601 Edit:sold
Please PM with any question. First I'll take it gets it. Please follow up with PM
Radio 1240, After the Fallout...Radio Free Chillicothe
 Post subject: Re: HP 204C audio generator & SENCORE PR57 Variable Iso Tran
PostPosted: Apr Fri 27, 2012 5:48 am
I will take the HP 204C, PM to follow
PostPosted: Apr Fri 27, 2012 12:50 pm
I'll take the Sencore Powerite, PM to follow.
PostPosted: Apr Fri 27, 2012 1:10 pm
If for any reason the deal falls through, I'm second in line for the Sencore.
If anyone else has one of these or something similar please PM me.
Keith Ostertag
Keith Ostertag
Harrisburg, PA
keitho at strucktower dot com
PostPosted: Apr Sun 29, 2012 2:49 am
No responds from ertzc2020 on the Hp 204C after sending him two PM's so the HP 204C is still available.
PostPosted: Apr Sun 29, 2012 3:48 am
I'll take the 204C
PM on the way.
Kris, WT5V
 Post subject: Re: HP 204C audio generator (sold)
PostPosted: May Wed 02, 2012 5:30 pm
Hotrod,
The Sencore arrived this morning. Looks good.
Thank you,
Post New Topic Post Reply  [ 7 posts ]  Moderators: John Bartley, Philco Fan
Users browsing this forum: al nicholson, CLEG, Exabot [Bot] and 3 guests
