It is currently Jun Tue 18, 2013 11:31 pm
Forum rules
 Post subject: SOLD: Fluke 8050A/-01 Benchtop/Portable RMS meter
PostPosted: May Sat 26, 2012 7:00 pm
Fluke 8050A/-01 Benchtop or Portable RMS Multimeter (Battery/AC)
4.5 Digit True RMS Digital Multimeter - Excellent Condition
(Actually it is a model 8050-01 because it has the internal rechargeable battery option)
Includes power cord, test probes and original manual.
Excellent condition – very clean and well cared for.
I replaced the rechargeable battery a few years ago so the meter can run for a limited time without AC.
I now have a Fluke 115 (gift from the wife) so it’s time to pass this guy on to someone else.
Price reduced from $60 to $50 plus shipping. I pay delivery confirmation.
Payment via Paypal or Postal Money Order.
Claim here first and then follow up with a PM with your complete mailing address.
Shipping from Chalfont, Pa 18914
Tech info from websites:
The Fluke Model 8050A Digital Multimeter provides superior performance and measurement capabilities in a low cost, benchtop instrument. These 4 1/2 digit DMMs have the following measurement functions:DC volts, true rms AC volts, DC amps, true rms AC amps, ohms, dBm (with selectable reference impedance's) conductance, and diode test. They also have a relative-reference feature that works with all measurement functions. These units also feature 0.03% basic dc accuracy and true rms from 20 Hz to 50 kHz. They also have overload protection. Rechargeable batteries are available in the model 8050-01 otherwise the 8050A operates on AC line power only
More detailed tech info:
FUNCTIONS: DC volts, AC volts (linear and dB), DC current, AC current, resistance, diode test, conductance and relative.
INPUT IMPEDANCE: 10 MOhms in parallel with <100 pF, all ranges
Dual slope integration A/D conversion to ensure noise free measurements.
DC VOLTAGE RANGES (10uv-1000vdc)
±200mV, ±2V, ±20V, ±200V, ±1000V ±(0.03% of reading +2 digits).
AC VOLTAGE RANGES (10uv-750vac)
±200mV, ±2V, ±20V, ±200V, ±750V ±(0.5% of reading +2 digits 40hz-10Khz).
(Average-Sensing, RMS Calibrated Sine Wave 40Hz to 10kHz)
DC CURRENT RANGES (.01ua-2A DC) ±(0.03% of reading +2 digits).
200uA, 2 mA, 20 mA, 200 mA, 2000 mA
AC CURRENT RANGES (.01ua-2A AC) ±(1% of reading +2 digits 40hz-10Khz).
RESISTANCE RANGES (.01ohms-20Mohms) ±(0.05% of reading +2 digits).
200ohm, 2K ohm, 200K ohm, 2000K ohm, 20 Mohm
Conductance measurements up to 100,000 Mohms
Excellent overload protection: 6kV @ 10msec
NORMAL MODE REJECTION RATIO: >60 dB at 60 Hz or 50 Hz
COMMON MODE REJECTION RATIO: >90 dB at DC, 50 Hz or 60 Hz
MAXIMUM INPUT: 1000V dc or peak ac continuous (less than 10 seconds duration on both the 200 mV and 2V ranges).
*DC Volts can also be measured using the dB mode with .01 dB resolution between 5% of range and full range.
RELATIVE REFERENCE: An input applied when the RELATIVE button is depressed to the ON position is held s
"0" reference point. Subsequent readings indicate the deviation (±) from this point.
(Note: REL annunciator indicates when this mode is enabled.)
TEMPERATURE COEFFICIENT: <0.1 times the applicable accuracy specification per °C for 0°C to 18°C and
28°C to 50°C (32°F to 64.4°F and 82.4°F to 122°F).
OPERATING TEMPERATURE: 0°C to 50°C (32°F to 122°F).
STORAGE TEMPERATURE: -40°C to +70°C (-40°F to +158°F).
SIZE: 22 cm X 6 cm X 25 cm
WEIGHT: 1.08 kg (2 lbs., 6 oz.)
STANDARDS: I EC 348 Protection Class 1
Preston Smith
Eureka, Pa
Trans-Oceanics: G500, H500, Y600, A600
Royal 94 Inter-Oceanic
Last edited by Preston Smith on May Sun 27, 2012 11:03 pm, edited 2 times in total.
PostPosted: May Sun 27, 2012 7:43 pm
Price dropped to $50 (will also make the change in my original post}.
These meters are selling from $60-$120 on the "E" place (that is, the ones that are not listed as "Parts Only"). I thought there would be more response for a Fluke benchtop model.
So, if you've been waiting for a price reduction - here it is! :wink:
FYI: I will not go any lower. Will take it to other auctions. Just want to offer it up here first because I've gotten some really good deals in the Radio Classified.
Thanks!
Preston Smith
Eureka, Pa
Last edited by Preston Smith on May Sun 27, 2012 11:01 pm, edited 1 time in total.
 Post subject: Re: FS: Fluke 8050A/-01 Benchtop/Portable RMS meter Battery/
PostPosted: May Sun 27, 2012 8:29 pm
Preston, I will take it. Sending PM
Stan Ski
PostPosted: May Sun 27, 2012 11:01 pm
Sold to Stan!
Preston Smith
Eureka, Pa
Post New Topic Post Reply  [ 4 posts ]  Moderators: John Bartley, Philco Fan
Users browsing this forum: DaMadFiddler, rdusel, Stan Ski, wwcarey and 5 guests
