It is currently Feb Thu 22, 2018 12:21 am
 Post subject: WTB Small Rotary Switch, FOUND
PostPosted: Jan Wed 11, 2017 2:53 am
I am in the need of Three (3) small 2P3P non-shorting rotary switches. I have ones that are 1 1/4 inches in diameter. But they won't fit into the space I have. So something 3/4 to 1 inch would be OK. 1/8" shaft is not an issue. PM me please. Thanks
 Post subject: Re: WTB Small Rotary Switch
PostPosted: Jan Wed 11, 2017 3:06 am
What voltage across the open contacts, and the highest voltage from any terminal to chassis?
PostPosted: Jan Wed 11, 2017 3:10 am
fifty volts max
PostPosted: Jan Wed 11, 2017 3:13 am
N2LXM wrote:
fifty volts max
OK.
Then I have to ask about current (max amps).
I generally don't worry about that in higher voltage circuits, but it can be high in LV circuits.
PostPosted: Jan Wed 11, 2017 3:14 am
sorry, should have post that as well. 1 amp max.
PostPosted: Jan Wed 11, 2017 6:29 pm
2P3P - which is poles, and which is position? Easiest is to state it outright with no abbreviations, or use the convention of Poles (p) and Throws (t). I've got several dozen small Grayhills, but I can't guess at poles/positions or positions/poles...
Brian
PostPosted: Jan Wed 11, 2017 7:30 pm
Sorry Brian, big fingers, not enough sleep the last few days. What I need is. 2 Pole, Three Position, Non-Shorting max working voltage 50 Volts, max current 1 Amp.
PostPosted: Jan Thu 12, 2017 3:04 am
Hi N2LXM,
I suggest you contact Mark Oppat. He ought to be able to fix you up. www(dot)*****(dot)net
Poston
PostPosted: Jan Thu 12, 2017 4:20 am
Thanks for the clarification - unfortunately, my Grayhill stuff is limited to 200mA at 28VDC...(51 series stuff, 5/8" round body...)
Brian
PostPosted: Jan Fri 13, 2017 5:20 pm
I have three NOS ceramic 3p3p with 1/8 inch shafts. The wafer is 1 inch at its widest point but the solder lugs stick out past that. Tip to tip on the solder lugs is 1.125 inches. You could easily bend the lugs to be parallel to the shaft to keep it down to 1 inch.
Tony Casorso
Post New Topic Post Reply  [ 10 posts ]  Moderator: Philco Fan
Users browsing this forum: 56Bird, LarryAD, Norm Leal, Philco Fan, Tronetix and 11 guests
