It is currently Jun Tue 19, 2018 7:14 pm
 Post subject: WTB: Indicator Lights
PostPosted: Jan Thu 04, 2018 12:00 am
I'm looking for indicator lights (the sockets/housing, not bulbs).
The ones I need are dim-able types, that have "DIM -> BRIGHT" written on the front. When you turn the front, it should increase or decrease brightness, via a little shutter, which looks like a radioactive sign. I need ones with red or green lenses. I'm interested in any quantity.
They also made them with amber lenses, but I already have a set of those.
On one that I already have, on the side of the front lens, in very faint stamp, is "C-42B-3593 2" The last number, in this case a 2, is the color code. 2 is amber, 3 is green, and I think, but I'm not sure, 1 is red. Green is the preferable color that I need.
I'd like to have the type with the metal socket mounts, as shown in the image, but I'd consider others. I'm trying to match the couple that I already have.
If you think that you have any, send me a private message. I will respond as soon as I see it.
IMAGES:
Thank you for your time,
-EJ
-Eli
http://www.FortCollinsB17.org
Last edited by RCAProduction on Jun Thu 14, 2018 3:01 am, edited 4 times in total.
 Post subject: Re: WTB: Indicator Lights
PostPosted: Jan Thu 04, 2018 2:18 am
Like the ones on this site
https://www.surplussales.com/Bulbs-Inca ... lLamp.html
PostPosted: Jan Thu 04, 2018 2:26 am
I've seen several varieties of these and also at least two different bulb sizes. We really need a photo and information on which bulb type. Do you want a push-to-test function included?
Jim Mueller
PostPosted: Jan Thu 04, 2018 3:42 am
Check your PMs, Eli.
Avery W3AVE
PostPosted: Jan Thu 04, 2018 4:48 am
DIALIGHT made every one I've seen in Avionics - they are still around. Fair Radio, eBay and Surplus Sales are all bound to have them. Most use a 327, 328, or 387 bulb, all the same size, just differing in intensity and bulb voltage.
Brian
PostPosted: Jan Thu 04, 2018 7:28 pm
Updated original post with images. As for bulb size, a #47 fits properly.
-Eli
PostPosted: Jun Thu 14, 2018 3:02 am
Bump. Still looking for green lens ones, and a few red ones.
-Eli
Post New Topic Post Reply  [ 7 posts ]  Moderator: Philco Fan
