It is currently Dec Tue 18, 2018 11:56 am
 Post subject: CLOSE: Uher 4000 Report-L Reel to Reel Deck: Update
PostPosted: Mar Thu 08, 2018 4:29 pm
Nice condition Uher 4000-L, 4 speeds uses up to 5" reels, mono sound, powered by 5 D-cell batteries.
Includes:
Uher take up reel
Uher original rechargeable battery (dead) takes up the space of 4 of the D cells
Leather carrying case (one strap has torn off snap, only used to keep strap end secure, metal piece holds weight of deck)
metal stand/handle
does not include:
Reel tapes
test results: motor runs, deck works, test tape played back a bit fast but likely due to deck that was used to record it. rewind and ff will work with some cleaning and lube of mechanism, it was cold outside when tested. controls are scratchy and could use some de-oxit, deck and case could use a good cleaning. still amazingly clean condition for the age.
$50 + shipping
That's good morning, wedgie style
KK4ROV
 Post subject: Re: FS: Uher 4000 Report-L Reel to Reel Deck: Update
PostPosted: Mar Fri 09, 2018 7:00 pm
Just found the original power supply, connector cable and Microphone
the power supply can be connected outside the deck to charge batteries or installed inside the deck to operate directly from the wall outlet
KK4ROV
 Post subject: Re: CLOSE: Uher 4000 Report-L Reel to Reel Deck: Update
PostPosted: Mar Sun 11, 2018 2:00 pm
Please close
KK4ROV
Post New Topic Post Reply  [ 3 posts ]  Moderator: Philco Fan
