It is currently Feb Sun 17, 2019 4:21 am
 Post subject: WTB - 1920's RF Coils - UPDATED
PostPosted: Jul Wed 04, 2018 11:57 pm
I am looking for plug-in coils for a 1922 Deforest Interpanel MR6. To cover the AM band I need the following amount/windings :
1- 100 Turns
1 - 25 Turns
They look like this......
[attachment=0]MR6 Coil 2e.jpg[/attachmen
Dan
Last edited by atwaterkent1 on Jul Thu 12, 2018 11:33 am, edited 3 times in total.
 Post subject: Re: WTB - 1920's RF Coils
PostPosted: Jul Thu 05, 2018 5:40 am
In no scenario will you need three of the same L-150 coils nor will you likely ever need a L-250 which covers 1300-4000 meters for broadcast use.
The following coils will get you the entire broadcast band for either the single primary circuit or for the balanced primary circuit. 2- L-150's, 1- L-100, 1- L-75, 2- L-50's, 1- L-35, 1- L-25
Alan
PostPosted: Jul Thu 05, 2018 6:14 am
Corrected 7/5/15.
305-710 and 150 - 355 meters covers the AM band and as you read across you can see that 2- 100's and 1- 50 cover the first range and 2 - 50's and 1-25 covers the 2nd range.
Dan
PostPosted: Jul Thu 05, 2018 2:13 pm
atwaterkent1 wrote:
According to the instructions the coils I asked for will do what I want done. Read for yourself.
460 - 1050 and 835 - 1950 meters covers the AM band and as you read across you can see that 2- 150's and 1- 100 cover the first range and 2 - 250's and 1-150 covers the 2nd range.
My mistake. I didn't realize the AM band was different in the northern US. Here in the southwest the AM band runs from 525 to 1705 kHz or 571 to 176 Meters.
Alan
PostPosted: Jul Thu 05, 2018 9:15 pm
My apologies Alan :oops: , the commercial range is no longer commercial. Corrections made. I don't know why the radio calls for different coils unless the circuit is set up differently.
Dan
PostPosted: Jul Thu 05, 2018 10:31 pm
Dan, I found this coil among the vast hoard of parts I acquired. See my post in June 2018 found. The person who had these items mounted many of the parts on cardboard with a description of the item. It was as if they were educational radio props. This item was interesting.
See attached photos,
Joe
Indiana Historical Radio Society
PostPosted: Jul Thu 05, 2018 10:32 pm
additional photo
PostPosted: Jul Fri 06, 2018 12:22 am
Sure looks like right type, but L-400 not listed as a coil used on this radio. I just got into this radio and it's my first with coils, so I don't know if you can use coils other than what's listed. I also am not sure if the diameter matters.
Dan
 Post subject: Re: WTB - 1920's RF Coils - UPDATED
PostPosted: Jul Thu 12, 2018 11:34 am
Bump
Dan
Post New Topic Post Reply  [ 9 posts ]  Moderator: Philco Fan
Users browsing this forum: k1ffx, Majestic-12 [Bot], wkmc and 14 guests
