It is currently Feb Wed 20, 2019 12:18 am
 Post subject: FOUND!! FEDERAL HEADPHONE SCREWS/See Picture/FOUND
PostPosted: Sep Mon 17, 2018 9:26 pm
I need 2 screws that go on top of the shafts for adjusting height of headgear in Federal Headphones.
They stop the shaft slider from coming of the top.
I went to nuts and bolts place in town and they said they did not know what thread that was; it was so small, so
I am thinking these screws might be just for this fit??????
So I am hoping someone has a parts set of headphones.
Thanks, Ray
 Post subject: Re: WTB FEDERAL HEADPHONE SCREWS/See Picture
PostPosted: Oct Mon 08, 2018 2:14 am
STILL LOOKING
PostPosted: Oct Mon 08, 2018 2:59 am
Looks like a #4-40 x 1/4" slotted pan head.
Diameter of the threaded part should be 0.112".
Diameter of the head should be 0.219".
These are about $1.50 per 100 at McMaster-Carr.
Very standard part, but smaller than stocked at most hardware stores.
PM me your address and I'll send you a couple. They won't be slotted, and not pan head, but
they'll work until you get the right ones. They'll also serve to confirm the 40TPI thread.
PostPosted: Oct Mon 08, 2018 2:37 pm
If they are #4-40 1/4 in. I have them in Phillips head.
Dale
http://www.dalesantiqueradio.com/
PostPosted: Oct Mon 08, 2018 8:37 pm
I brought the correct screw to a place that is what they specialize in, nuts and bolts, and they said it was an odd size, but did not know what size.
I took a screw of a Brande's head set, and it started to screw in but then it stopped.
thanks
PostPosted: Oct Mon 08, 2018 8:54 pm
4-36 threads used to turn up in some mechanical equipment. Sorry, I don't have a source.
-Chuck
PostPosted: Oct Tue 09, 2018 3:04 am
Google 4-36 machine screws.
Dale
PostPosted: Oct Tue 09, 2018 4:26 pm
#4-36 is a standard thread.
McMaster-Carr carries them.
PostPosted: Oct Tue 09, 2018 5:03 pm
Thanks, but if it is a standard thread it would not be the one I need according to;
http://reliablehardwareandsteel.com/
PostPosted: Oct Tue 09, 2018 5:45 pm
If you know what you need, why are you asking ?
PostPosted: Oct Tue 09, 2018 6:18 pm
Reliable Hardware says they do not know what size thread it is; they say it must be a odd one.
PostPosted: Oct Tue 09, 2018 7:38 pm
How do they know?
Did you send them one to measure?
Considering they said #4-36 is not a standard size, when in fact it is...
I would question any analysis they might provide.
PostPosted: Oct Tue 09, 2018 7:44 pm
I took one down there, and it did not screw in their measuring tool.
Are you sure it is a 4-36?
PostPosted: Oct Tue 09, 2018 9:07 pm
No, I'm not.
I was commenting on their assertion that #4-36 was not a standard thread.
It is standard, but less common than #4-40.
And of course I'm __assuming__ that it's an English thread, not Metric.
PostPosted: Oct Tue 09, 2018 10:09 pm
Thanks Leigh
I am a collector; I do not no much about anything.
I guess I was dreaming and hoped someone had a old set of Federal headphones around that were trashed
and I could get the screws from it..
This place I went to has been in business longer then I been alive I think. I am just going by what they said.
PostPosted: Oct Tue 16, 2018 4:35 pm
I just went to Fastenal and they said it is a #4-40.
They did not have any so they ordered me 5 of them.
I will post again when I know for sure they are the right ones.
PostPosted: Oct Mon 22, 2018 6:04 pm
Leigh was right they are 4-40 1/8 in.
Thanks everybody. I might get 1/4 in. for length next time.
Post New Topic Post Reply  [ 17 posts ]  Moderator: Philco Fan
Users browsing this forum: cjr W7JBA, dneprrider, dsturz, G.S.D., hbr nut, Jim Mueller, w3jn, xrhonda91 and 12 guests
