It is currently May Sun 19, 2013 10:00 am
 Post subject: 20 AWG Wire (Plastic) and 18 AWG (Cloth) - lowest price?
PostPosted: Jul Fri 20, 2012 1:14 am
Greetings Folks!
I need to buy some wire for my repair bench. Ideally, 50 Ft of different colors of 20AWG with plastic (not nylon) coating and some 18 AWG with cloth coating.
Where's a great place to buy wire at a very low price and shipping?
Thanks!
Preston Smith
Eureka, Pa
Trans-Oceanics: G500, H500, Y600, A600
Royal 94 Inter-Oceanic
 Post subject: Re: 20 AWG Wire (Plastic) and 18 AWG (Cloth) - lowest price?
PostPosted: Jul Fri 20, 2012 7:47 pm
I buy mine from Radio Daze.
http://www.radiodaze.com/
Ed.
PostPosted: Jul Fri 20, 2012 8:19 pm
If you are going to be basing the wire on price....
the cheapest source I've found for PVC insulated stranded wire in different colors is to
reclaim the wire from old control cables. You can try local scrap dealers, etc. The wire is
good quality, but it is a bit of work to remove the outer covering on the cables, and you may
have to guess at the working voltage.
Pete
A long journey always begins with the words, "I think I know a shortcut."
PostPosted: Jul Sat 21, 2012 12:08 am
Thanks Guys!
Radiodaze only sells 22AWG. Any concerns about using 22AWG in place of 20AWG?
Preston Smith
Eureka, Pa
PostPosted: Jul Sat 21, 2012 12:46 am
Free air ampacity for 20AWG=11A, 22AWG=7A. It's lower for bundled wires or other conditions. So it might be ok to substitute, depends what you're using it for.
PostPosted: Jul Sat 21, 2012 2:58 am
I'd be leary in parallel filament voltage feeds, especially if the tube socket
wiring is daisy chained. The voltage drop on the lighter AWG wire might
have to much resistance and cause a voltage drop, especially at the last tube
being fed filament voltage. It would be even more critical for early sets
using 2.5 volt tubes because of the increased current draw.
to be safe:
Never go with a lighter gauge than was used originally for the filament wiring.
Pete
PostPosted: Jul Sat 21, 2012 4:30 am
Troll thrift shops and or Goodwill stores for the old 25 conductor parallel printer cables. You can find them as long as 25 foot. Lots of wire inside <g>
It's easier to make a steam powered lobster trap than a lobster powered steam trap
PostPosted: Jul Sat 21, 2012 6:24 am
Whatever wire you find, be sure to look at the voltage rating on it.
Most of the new stuff I see has a max of 300V :shock: , whereas many old radios can run up to 600V.
Typically I just by the 600V wire.
FrankB
WB7ELC
Member: TCA
"I know that all that is wrong with it is one little part".
PostPosted: Jul Sun 22, 2012 3:52 pm
Thanks Frank - good advice on the voltage requirements.
Doesn't anyone here buy 20 AWG wire and have a recommendation?
Preston Smith
Eureka, Pa
PostPosted: Jul Mon 23, 2012 11:50 pm
Just bought some 20 gauge rolls from All electronics.com. Prices seem pretty decent. Check out there site
Stan Ski
PostPosted: Jul Tue 24, 2012 4:25 am
Excellent! Thanks Stan!
Preston Smith
Eureka, Pa
Post New Topic Post Reply  [ 11 posts ]  Moderator: Peter Bertini
