Page 1 of 1
[ 9 posts ] |
| Author |
GuitarGuyNack
Post subject: Reading dog bone resistors New question added Posted: Aug Fri 10, 2012 7:54 pm |
| Member |
Joined: Jun Thu 17, 2010 5:41 pm Posts: 1576 Location: Dawson Creek BC, Canada
How do i figure out the values of dog bone resistors?Do the colors indicate the same values as the color bands on newer resistors?
Nick
_________________ Nick Life without music would be a mistake-Nietzsche I am not accountable for any damage this causes
Last edited by GuitarGuyNack on Aug Fri 10, 2012 10:24 pm, edited 1 time in total.
| Top |
Peter Bertini
Post subject: Re: Reading dog bone resistors Posted: Aug Fri 10, 2012 7:59 pm |
| Moderator |
Joined: Jan Thu 01, 1970 1:00 am Posts: 12215 Location: Somers, CT
Unless they are very old, or Atwater Kent resistors, they follow a BED color code.
Body color, End color, Dot color. In that order.
Use the same color code as you would for banded resistors.
_________________ A long journey always begins with the words, "I think I know a shortcut."
| Top |
GuitarGuyNack
Post subject: Re: Reading dog bone resistors Posted: Aug Fri 10, 2012 8:27 pm |
| Member |
Thanks Peter.
Nick
| Top |
GuitarGuyNack
Post subject: Re: Reading dog bone resistors Posted: Aug Fri 10, 2012 10:22 pm |
| Member |
New question. How do i figure out the values of these resistors?(i think their resistors) Attachment:
They all have one black end and 2 wide bands of the same color with a different color in the middel.None of the resistance readings i'm getting from them match up with resistor color codes though. Nick
| Top |
Jack Shirley
Post subject: Re: Reading dog bone resistors New question added Posted: Aug Sat 11, 2012 12:28 am |
| Member |
Joined: Mar Fri 14, 2008 1:40 pm Posts: 8407 Location: SE USA
Body=Blue (6). End=Black (0). Dot(band) = Orange (000)
60k.
_________________ The beatings will continue until the morale improves
| Top |
Tim Tress
Post subject: Re: Reading dog bone resistors New question added Posted: Aug Sun 12, 2012 3:10 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 5763 Location: Beaver Falls, PA. USA
There has been discussion of those resistors here from time to time; they are read the same as the "dogbone" types, except that the dot is usually replaced by a color band in the middle. However, some very early versions did use a dot.
They are the insulated "BT" type made by IRC, and are often found in equipment from the 1935-42 era. Philco, Crosley, and Scott used them heavily, but they turn up in other makes as well.
_________________ Tim KA3JRT
| Top |
Leigh
Post subject: Re: Reading dog bone resistors Posted: Sep Tue 11, 2012 6:09 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 17602 Location: Maryland 21046
| Top |
Steve Johnson
Post subject: Re: Reading dog bone resistors New question added Posted: Sep Sun 16, 2012 8:17 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 4980 Location: Upstate NY, USA
| Top |
BigBandsMan
Post subject: Re: Reading dog bone resistors New question added Posted: Sep Mon 17, 2012 3:34 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6032 Location: Raleigh NC USA
Many thanks for posting the chart, Steve.  Larry
_________________ It don't make a go if it ain't got that GLOW!
| Top |
