It is currently May Fri 24, 2013 3:58 pm
 Post subject: What Would You do With a....
PostPosted: Aug Sat 18, 2012 2:08 pm
tested very strong, Zenith 6X5G?
- Greg
WD8PHW
 Post subject: Re: What Would You do With a....
PostPosted: Aug Sat 18, 2012 2:50 pm
1: Sell it to someone who wants an engraved Zenith tube..
2: Be proactive and find a spare power transformer before the tube shorts....
3:
4:
I'll some blanks for other guys to fill in :wink:
A long journey always begins with the words, "I think I know a shortcut."
PostPosted: Aug Sat 18, 2012 4:28 pm
Ebay. Or tube collection. Possibly some smart person took it out before it wrecked a transformer.
PostPosted: Aug Sat 18, 2012 4:32 pm
6X5G is similar to an 84. They were used in many radios which didn't have problems. Be sure the tube doesn't have shorts, then it could be used within it's limits.
Zenith did use 2 - 6X5's in some radios. That design had a much higher failure rate for the rectifier.
PostPosted: Aug Sat 18, 2012 4:47 pm
My 667 says no shorts.
This tube came out of a Zenith 5808 chassis (8S463). I haven't gotten around to checking the transformer, since, for now anyway, I'm only interested in the cabinet.
All of the tubes are Zenith, and most are usable. The 6F6G shows a 1 Meg H-K short, but it was tested in a functioning 5808, and it worked fine. I hastily tested it's merit too, and it's 120! The 6U5 was missing on arrival! :evil:
- Greg
WD8PHW
PostPosted: Aug Sat 18, 2012 7:44 pm
Greg
Only one 6X5G in 8S463 radio. If it tests good, without shorts, tube is usable. Someone would want an original Zenith 6X5G with engraved base.
PostPosted: Aug Sun 19, 2012 10:01 pm
here is My 0.02 cents on the topic of 6x5 tubes in zenith radios. Just make a 84 to 6x5 adapter or use a 84m tube
''What's With All The Quotes In Everyone's Signatures''
PostPosted: Aug Mon 20, 2012 6:07 pm
gvel wrote:
My 667 says no shorts...
You mean for now, as last heated up, I presume!
Cheers,
Roger
Roger Jones, P.Eng, SMIEEE.
Thornhill, Ontario
PostPosted: Aug Sat 25, 2012 4:20 pm
I re-heated the 6X5, in the 5808. It ran for a an hour...no trouble.
Yes...I know...this was a short test, and it's only one data point, but the tube functions as designed.
On a side note, the power transformer, on this 5808, runs cooler than any other radio that I have.
- Greg
WD8PHW
PostPosted: Aug Sat 25, 2012 4:54 pm
In the past I have gotten Zeniths in for service with either rewired sockets or replacement sockets (also a replacement transformer of course) and I restore it to 6X5G configuration with a proper transformer. I then plug in solid state replacements for 6X5's I make which should last indefinitely. The thing to be concerned about is what can happen down the road. A new owner will get a schematic and note that the radio should have a 6X5G in it and will try to plug one in. I prepare a folder with all services done on a radio to go with the radio but I don't count on someone passing it along with the radio when they sell it later on. I try to keep a radio in it's original configuration so future owners won't be scratching their head(s) trying to work out what was done to it in the past. I also fix a permanent label to restuffed filters stating the contents and the date the restuffing was done. I only keep 6X5's for my other equipment that can use them such as my EICO 315. I sell any excess.
PostPosted: Aug Sat 25, 2012 6:03 pm
I simply use 6X5WA's in my Zeniths and dont worry about it since Im not selling them. If I were to sell, then including an engraved 6X5G (one or two) with a proper caveat, might interest the buyer if the other tubes also matched the originals.
PostPosted: Aug Wed 29, 2012 6:14 pm
what is the difference between a 6x5 and a 6x5wa?
PostPosted: Aug Thu 30, 2012 8:49 pm
The last two letters :lol:
It stands for ruggedized, usually shock resistance and/or improved insulation
PostPosted: Aug Thu 30, 2012 10:41 pm
Far too much spoken about this one, but I would recommend a moderate fuse, and never leave the room or dare fall alsleep whilst playing the set. Of course you could get a couple of diodes for a dime.
PostPosted: Sep Fri 07, 2012 11:17 pm
Maybe I should sell it!?
http://www.ebay.com/itm/221119162741?ss ... 1438.l2649
- Greg
WD8PHW
PostPosted: Sep Sat 08, 2012 12:08 am
You may get more being a Zenith with engraved base.
PostPosted: Sep Sat 08, 2012 2:21 am
Every shorted 6x5 showed no shorts before it shorted.
A short circuit is instantaneous. Once it occurs, it cannot be reversed.
73 de Leigh W3NLB
http://www.AtwaterKent.info (Click on Grebe Stuff for Synchrophase info)
PostPosted: Sep Sat 08, 2012 1:35 pm
Maybe this will help:
viewtopic.php?f=19&t=193858
:wink: Larry
PostPosted: Sep Sat 08, 2012 9:19 pm
Nice to see you back. I had to look at the date on the posts to make sure this was not an old thread or I was in a time warp!
PostPosted: Sep Sat 08, 2012 11:15 pm
Thank you, Scott. I'm warped, but not time warped. :D
73 de Leigh W3NLB
Post New Topic Post Reply  [ 20 posts ]  Moderator: Peter Bertini
