It is currently Nov Sat 18, 2017 2:48 pm
 Post subject: 6BQ5 / 7189 /6P14P
PostPosted: Aug Wed 02, 2017 3:51 pm
I have 3 stereo 6BQ5 amps to repair and need 16 of them for the amps . Even the russian ones seam high price right now !
8BQ5's are even fairly high and is there another alternative .
Mark
 Post subject: Re: 6BQ5 / 7189 /6P14P
PostPosted: Aug Wed 02, 2017 4:26 pm
I've used the 6P14P-EV OTK with great success. Now they run $12-15 each. You won't see good ones for much less than that. They'll be from old Russian stockpiles from Ukraine and other former Soviet satellites.
PostPosted: Aug Wed 02, 2017 8:57 pm
I have had great luck with 10BQ5s. Not too hard to find for $10 or so each. Can be run on 6.3v pleasently, though I had an over-sized filament transformer, so bumped over to DC to get it closer to 10v.
PostPosted: Aug Wed 02, 2017 11:00 pm
I repaired a German Stereo and use 4 8BQ5's in it. Had plenty of volume and sounded great.
PostPosted: Aug Wed 02, 2017 11:09 pm
Bob Dobush at www.FindAtube.com is showing his 8BQ5 tubes at $6 new and $3 used.
https://docs.google.com/spreadsheets/d/ ... 0foD#gid=3
PostPosted: Aug Thu 03, 2017 12:31 am
What price do you consider reasonable?
With a minor socket rewire you can substitute the electrically equivalent 6GK6, 8 bucks each at ABCvacuumtubes.
http://www.abcvacuumtubes.com/vacuumtub ... -6jz8.html
If you want to be a little more adventurous try the 6HB6 for only 3 bucks each. It's similar to a 6BQ5 but with twice the gm (takes rebiasing).
I've used both in my '6BQ5' type amp designs.
PostPosted: Aug Thu 03, 2017 1:16 am
Same people in Orlando, just a different name. And, the same price.
http://www.esrcvacuumtubes.com/vacuumtu ... -6jz8.html
PostPosted: Aug Thu 03, 2017 1:39 am
The guys [Stan] in Orlando don't test the tubes before they go out, so check them.
PostPosted: Aug Sat 05, 2017 3:37 am
6P14P-K-EL84-6BQ5-100-Tested-Tubes-Military-Lot-of-24-USED
I ended up buying a lot of 24 used supposedly good Russian tubes .
http://www.ebay.com/itm/6P14P-K-EL84-6B ... 1438.l2649
Mark
PostPosted: Aug Sun 06, 2017 2:10 am
6-8 years ago, I purchased a lot of soviet 6BQ5 type tubes from this seller. some were the ruggedized versions.
they were/are fantastic tubes.
http://www.ebay.com/usr/gobble75?_trksid=p2047675.l2559
check out what he has in the line of soviet 6BQ5 equivalents.
steve
I am not responsible for any damage, injury, or death from any content / advice in this thread.
PostPosted: Aug Mon 07, 2017 1:20 am
Ouch! $6-8.00 for good ones I right. I have some, and at least that's what I would get for 'em. Not for sale now.
PostPosted: Aug Mon 07, 2017 1:26 am
i got them much cheaper years ago when the market was not asking that much.
i believe i paid about $2 a piece.
deaspite the expense now, they are fantastic tubes.
steve
PostPosted: Aug Sun 13, 2017 3:13 am
most push pull amps should use matched pairs. you need them to bias the same. this is not the same as showing the same number on a tube tester. if tubes are from the same production lot that increases the odds you will find some that match acceptably.
PostPosted: Aug Sun 13, 2017 3:17 am
absolutely on the above
luckily, the pile i purchased all matched up quite well with only a few not matching with a partner.
steve
Users browsing this forum: Clutter and 8 guests
