It is currently Jun Wed 20, 2018 8:35 am
Post New Topic Post Reply  [ 51 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Rarest Vacuum tubes for old radios? What ones are rares
PostPosted: Jun Wed 13, 2018 8:47 pm
is there any truth to this statement:
operating a radio with a weak audio output tube can cause stress on other components.
IDK whether this is hogwash or not, and it matters not to me b/c i don't do it, but hopefully someone can confirm it for curiosity's sake.
i heard/read this somewhere.
steve
I am not responsible for any damage, injury, or death from any content / advice in this thread.
PostPosted: Jun Wed 13, 2018 8:58 pm
Steve
Although I don't remember seeing it a weak output tube can put stress on other components. When an output tube is weak emission will be down. This causes the tube to draw less current. Less current allows higher voltage on the B+ line for other components.
PostPosted: Jun Wed 13, 2018 9:32 pm
I've not heard of such a thing, and have not found it to be true.
I do remember many years ago hearing about installing a new CRT in a TV puts stress on the rest of the set's older components.
Again, I've never seen any proof to this concept.
PostPosted: Jun Thu 14, 2018 2:05 am
understood
steve
PostPosted: Jun Fri 15, 2018 2:53 am
How about the 50A1 ballast used in some Transoceanics?
― R. A. Heinlein
PostPosted: Jun Sun 17, 2018 12:31 am
The engineers over at Majestic (Grigsby-Grunow) had a thing for odd tubes, such as the spray-shielded types, the G-2-S and G-4-S detector diodes, the G-84 rectifier (half an 80), and many others that were unique to that brand.
Kevin Grimm
"If it doesn't fit, force it. If it breaks, it needed replaced anyways."
PostPosted: Jun Sun 17, 2018 12:35 am
I believe those off spray shield tubes were actually Canadian origin with the Rogers-Majestic connection.
PostPosted: Jun Sun 17, 2018 1:06 am
Sparton produced a special tuning indicator tube for some of their 1935 models called the VG-1. (Viso-Glo)
So that's what that odd little tube I've had for years is! Until now I had no idea what it was or what set it was used in!
Kevin Grimm
PostPosted: Jun Sun 17, 2018 1:11 am
The only radios that I am aware of that used the Armor AC100 tube were a couple of early Garod ac receivers, the EA and EM
Kevin Grimm
PostPosted: Jun Sun 17, 2018 1:39 am
Wow, you have one?
My Sparton 136 is missing its tube, if you have any thought as to parting with it.
PostPosted: Jun Sun 17, 2018 4:09 pm
I don't have any radios that use it, so I'd let it go. Bear in mind, however, that I have no way of testing it, so its condition is unknown.
Kevin Grimm
