It is currently Jan Sat 19, 2019 3:21 am
 Post subject: Transformer Question
PostPosted: Nov Fri 09, 2018 2:33 am
I have been working on an older Trio 9R-4J receiver. When I got it it had a transformer connected under the chassis for the audio output. I removed it since it had been very poorly installed and was in the way. It didn't appear to be an original item. I did some tests on it and the impedance didn't seem correct for the tube that was installed (that was fried BTW). Using a variac I got 1VAC out with 75VAC in. This would seem to make the impedance like 15K with a 4 ohm speaker if I calculated correctly. The output tube was a 6AQ5 set up single ended which requires a 5K to voice coil so this seems way too high.
DC resistance on the primary was 360 ohms, secondary maybe .2 ohm. There is a small schematic on the top showing a jack labeled tip/ring/sleeve with the other side voice coil and a speaker symbol. There was also a number on the schematic SC-A-3725-A. May be military since it has metal end caps.
Any idea what this transformers intended use may have been? What output tube (if any) it was intended to be used with?
 Post subject: Re: Transformer Question
PostPosted: Nov Fri 09, 2018 2:35 am
Tip + ring would be telephone use.
Scott.
PostPosted: Nov Fri 09, 2018 2:43 am
Or also for headphone jack wiring.
PostPosted: Nov Fri 09, 2018 2:51 am
Try using a signal generator at 1khz. Using the variac you are trying to push 60hz through and it might not have the core size to do that. Put 1v on the sec, measure the primary, much easier. 6aq5 isn't gonna really care what impedance, 4k, 5k, 8k,.
PostPosted: Nov Fri 09, 2018 3:07 am
I will try the audio generator as suggested.
I was looking on line and stumbled across a site that showed the inside of a military LS-3 speaker; the transformer inside had an almost exact small schematic as the one on the transformer I have, complete with tip/ring sleeve, etc. Likely this transformer was used in some military speaker enclosure.
PostPosted: Nov Fri 09, 2018 4:09 am
I would purchased a used correct audio transformer off of ebay. Some list primary & secondary impedance or tube that was used with the transformer.
PostPosted: Nov Fri 09, 2018 4:17 pm
60 Hz is fine for measuring a transformer - frequency won't effect the unloaded ratio, though obviously the primary impedance drops with frequency and it will load the source more. 5-8K primary is typical for 6AQ5 (or 6AR5, commonly used in Japanese equipment)
PostPosted: Nov Sat 10, 2018 7:21 am
But it can affect the measurement if the core is too small and saturates. Then the output voltage would be lower than what the turns ratio would suggest.
PostPosted: Nov Thu 22, 2018 11:19 pm
I test many small transformers, power and signal, with a 60 Hz variac. The key to "no saturation" is to watch the unloaded primary current on an AC meter as you increase the test voltage. Don't apply any voltage higher than that at which the current starts to increase; use a lower voltage. Example: some power transformers start to "take current" (unloaded) at over 130 VAC on the primary. At 115 VAC they are fine.
Cheers,
Roger
Roger Jones,
Thornhill, Ontario
