It is currently May Sat 25, 2013 12:13 am
 Post subject: 85 tube
PostPosted: Mar Sat 13, 2010 5:10 am
anyway to sub this have a lot other 6 pins and perhaps use a couple of germaniums as the detectors/or should a 85 be easy to buy?
this is the last tube i need on a delco radio
thanks for reading
jim
PostPosted: Mar Sat 13, 2010 5:21 am
$4 new, $2 used at findatube.com
PostPosted: Mar Sat 13, 2010 5:23 am
You can buy an 85 for less than $10, and there's plenty of them. You could replace the internal diodes with silicons but not the triode of the 85. Just buy you a new tube.
Steve McDonald
85s are cheap and easy to get. For testing you could try a 75 but it will provide too much gain in the first audio stage and you may get some squealing. Or it may work fine. If you have one, all you can do is try it.
paul - http://personalpages.tds.net/~pdieten
A 75 will sub...
PostPosted: Mar Sat 13, 2010 5:51 am
thanks all beleive i have a 75 until i can get a 85
Post New Topic Post Reply  [ 6 posts ]  Moderator: Peter Bertini
Users browsing this forum: Curmudgeon, Jack Shirley and 2 guests
