Page 1 of 1
[ 10 posts ] |
| Author |
commanderhix
Post subject: Mysterious speaker Posted: Feb Fri 17, 2012 1:23 am |
| Member |
Joined: Feb Fri 17, 2012 1:14 am Posts: 30 Location: washington
| Top |
markjd
Post subject: Re: Mysterious speaker Posted: Feb Fri 17, 2012 4:43 am |
| Member |
Joined: Mar Tue 02, 2010 6:53 pm Posts: 297 Location: Virginia
If I had to guess, it looks like an intercom speaker with buzzer... 40's vintage with that black crackle paint and cord.
Mark
| Top |
commanderhix
Post subject: Re: Mysterious speaker Posted: Feb Fri 17, 2012 4:48 am |
| Member |
thanks, as soon as i finish with the stand i'll get some pictures up and see if that helps any to get more specific dating and stuff  thanks!
_________________ ~Kyler
| Top |
battradio@
Post subject: Re: Mysterious speaker Posted: Feb Fri 17, 2012 5:27 am |
| Member |
Joined: Jul Fri 18, 2008 10:02 am Posts: 1372 Location: near ST Louis Mo
It is a balanced armature speaker , it should be highly sensitive and used with very low power output devices such as a low power tube battery radio
_________________ Mark
| Top |
markjd
Post subject: Re: Mysterious speaker Posted: Feb Fri 17, 2012 5:47 am |
| Member |
So much for guessing... Never seen one before, but it looks interesting. Could be from earlier than the 1940's if that's what it is.
| Top |
commanderhix
Post subject: Re: Mysterious speaker Posted: Feb Fri 17, 2012 6:04 am |
| Member |
I was wondering what that type of speaker was called. I really appreciate the information. If you want, check back tomorrow and i should have some pictures up of the stand, as well as a few pictures of the speaker with the grill cloth.
| Top |
Harold Wright
Post subject: Re: Mysterious speaker Posted: Feb Wed 22, 2012 2:48 am |
Joined: Mar Sun 29, 2009 3:34 am Posts: 520 Location: chancellor al.
[quote="battradio@"]It is a balanced armature speaker , it should be highly sensitive and used with very low power output devices such as a low power tube battery radio[/quote]
I concur with above quote. It is very probably a high impedance speaker; not your typical 4 or 8 ohm type (I would guess about 2000 ohms impedance)
Harold
| Top |
radiotechnician
Post subject: Re: Mysterious speaker Posted: Feb Wed 22, 2012 6:56 am |
Joined: Sep Thu 23, 2010 6:37 am Posts: 3956 Location: Powell River BC
Armature speakers are what hearing aids use today. They finally have got the computer power needed to analyze why they work the way they do and tweak them.
| Top |
Geoff Fors
Post subject: Re: Mysterious speaker Posted: Feb Wed 29, 2012 11:56 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2432 Location: Monterey California USA
A couple manuals I have refer to them as a "magnetic" speaker. Apparently popular on small battery operated gear as mentioned above.
_________________ WB6NVH
| Top |
codefox
Post subject: Re: Mysterious speaker Posted: Mar Thu 01, 2012 12:18 am |
Yes, they were early portable radio (not so) loudspeakers. You could restore as a curiosity, but frankly the quality is pretty poor. If you have a set that otherwise is OK, you could sub a (PA) 70.7 volt distribution to voice coil, use a 4 or 8 ohm PM speaker, and that's it.
| Top |
