It is currently May Wed 22, 2013 7:18 am
 Post subject: Electrolitic capacitor question
PostPosted: Mar Mon 19, 2012 2:03 am
I have an RCA combo tv stereo from 1968 I picked up. The radio has a 4 section paper electrolitic cap that needs replaced. I cant find replacements for 2 of the sections. The values are 1500mfd 35 volt and 1000mfd 35 volt. The closest thing I can find are 500mfd at 50 volts. I would have to use 5 caps to replace 2. Does anyone know where I can get caps closer to those values without having to use so many caps?
Thanks,John.
 Post subject: Re: Electrolitic capacitor question
PostPosted: Mar Mon 19, 2012 2:12 am
Mouser has 1000 and 2200 in Nichicon axial lead and there are more choices in radial.
PostPosted: Mar Mon 19, 2012 4:00 am
1500 is not a common value. 1800 is a common value. Use that. Mouser has a ton at under $2.
PostPosted: Mar Mon 19, 2012 4:03 am
Looks like I lied. Mouser also has 1500 under $2
PostPosted: Mar Mon 19, 2012 4:05 am
Yes, Mouser does carry those values at very good prices. I would certainly check there. Shipping is rather speedy too.
PostPosted: Mar Mon 19, 2012 3:06 pm
What brands are under $2 ? I looked last night and saw some for around $7.50. The old multisetion has 2 negative leads. Why is that? Also does mouser carry grommets for record changers?
PostPosted: Mar Mon 19, 2012 5:45 pm
There are many choices in radial leads, axial are obsolete and being slowly phased out so choices are decreasing.
PostPosted: Mar Tue 20, 2012 2:27 am
I saw Panasonic under $2
Post New Topic Post Reply  [ 8 posts ]  Moderator: Peter Bertini
Users browsing this forum: fifties and 3 guests
