It is currently May Sun 19, 2013 4:10 pm
 Post subject: How to I test WD-11's?
PostPosted: Mar Mon 26, 2012 4:41 am
I have two sets I recently acquired with WD-11 tubes. I have no way to test the tubes. The filaments show continuity.
Is there an adapter available for my tube tester's four prong socket?
Thank you.
Andy
 Post subject: Re: How to I test WD-11's?
PostPosted: Mar Mon 26, 2012 5:08 am
Be very careful checking continuity on WD-11's. Some voltmeters will burnout the filament. You will have to make adapters for your tube tester as I did over thirty years ago and you will need to create the setup to test the tubes reliably. If you make an error, you will fry an expensive tube. Stick to testing incircuit to avoid a costly mistake.
PostPosted: Mar Mon 26, 2012 12:30 pm
So long as the filaments are good, there is a high chance the tubes will still be good. When testing or playing your radios I would use the WD-11 substitutes, or an adapter.
http://dialcover.com/tubes.html
PostPosted: Mar Mon 26, 2012 2:36 pm
Thank you!
Andy
Post New Topic Post Reply  [ 4 posts ]  Moderator: Peter Bertini
Users browsing this forum: ekimetsok and 4 guests
