Page 1 of 1
[ 5 posts ] |
| Author |
drdave
Post subject: 35C5 Posted: Apr Fri 13, 2012 7:26 pm |
I have been working on a Philco 49-905. I had concerns about its 35c5 audio output tube. I checked it, and then checked about 5 more in two of my tube checkers. The others were NOS tubes. They all showed shorted and bad emissions, etc. I triple checked my settings on both checkers. Is there something I'm doing wrong.
Also, could I sub a 50C5 for that one?
Thanks, David
| Top |
codefox
Post subject: Re: 35C5 Posted: Apr Fri 13, 2012 7:29 pm |
Sure can. Will help with the increased line voltage we have now. Just curious, test a 50c5 on the same tester. Same results?
| Top |
Norm Leal
Post subject: Re: 35C5 Posted: Apr Fri 13, 2012 7:31 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 28969 Location: Livermore, CA
David
A 50C5 will work. Good idea if line voltage is high. It just takes longer to heat.
You mentioned tubes are NOS. Are you sure? These tubes will get heater to cathode leakage after a lot of use.
_________________ Norm
| Top |
drdave
Post subject: Re: 35C5 Posted: Apr Fri 13, 2012 7:34 pm |
I recently acquired a lot of tubes from an old TV shop. As far as I can tell, these 35C5's are not used, but then, how do you know? Thanks for the fast response.
| Top |
glasdave
Post subject: Re: 35C5 Posted: Apr Tue 17, 2012 5:33 am |
| Member |
Joined: Feb Tue 24, 2009 8:20 am Posts: 7727 Location: Aurora Colorado
If the tube matches the box it's in, you have a better chance of a good/NOS tube. Some techs replaced weak tubes, and they can be used in certain set just fine. A tester, and a radio are your best bets!
_________________ I move the world just one step on...
| Top |
