It is currently Jun Thu 20, 2013 1:23 pm
 Post subject: ballast tube replacement How is value determined?
PostPosted: Apr Sat 14, 2012 4:03 pm
I am working on a Zenith 6D311. The set came with a ballast tube, but the dial lamp did not work. After spending some time trying to find the source of why the pilot lamp did not work, I eventually came to the conclusion that I had one last idea. The two wires to the lamp were connected to the ballast tube.
I had a spare ballast tube from another set and made the switch. The pilot lamp glowed nicely.
How do I buy another ballast tube? The schematics for the Zenith 6D311 only states that it is a ballast tube.
Can any type be used?
 Post subject: Re: ballast tube replacement How is value determined?
PostPosted: Apr Sat 14, 2012 4:18 pm
Hi
Ballast tube is a Zenith 100-70. It drops 49 volts @ 300 ma. There is a jumper between pin #3 and #4. Main resistance element between pin #3 and #7. Lamp tap between pin #7 and #8.
This is a popular voltage drop. Ballasts like K49B would work but need to jump pins #3 and #4 at the socket.
Check AES, www.tubesandmore.com or PTOP http://www.oldradioparts.com/2a2fl.txt
PostPosted: Apr Sat 14, 2012 5:08 pm
I understand.
Thank you.
PostPosted: Apr Mon 23, 2012 6:05 am
AES has the T-URB-009-BT, they show the resistors in it. You would need to jumper pins 1&2.
Diode Don, all problems rectified.
Someone with less knowledge than I had been in there before ....
PostPosted: Apr Tue 24, 2012 8:53 pm
Has anybody actually bought an used a URB-009? The web page is missing info, I asked AES, and they never answered.
Dave Wise
PostPosted: Apr Tue 24, 2012 10:29 pm
Dave, What info do you need? It shows which pins the resistors are connected to, I hope the diagram is correct, and it goes in an octal socket. Ohms Law shows that you need all of the resistance, so jumper pin 1 &2 in the socket.
PostPosted: Apr Tue 24, 2012 11:09 pm
Sorry Don, I meant URB-010. It's the blank one, not URB-009. I mistook URB-009 for it. So my question is off-topic, but still: Does anyone have specs on URB-010?
Dave Wise
PostPosted: Apr Wed 25, 2012 3:16 pm
Dave, The URB-010 is a mystery. Open a new topic for it, see what answers you get. It can still be ordered.
PostPosted: Apr Wed 25, 2012 5:35 pm
True enough, and it's just a few bucks. Next order, I'll get one.
Dave Wise
Post New Topic Post Reply  [ 9 posts ]  Moderator: Peter Bertini
