Page 1 of 1
[ 9 posts ] |
| Author |
decoflair
Post subject: ballast tube replacement How is value determined? Posted: Apr Sat 14, 2012 4:03 pm |
Joined: Apr Fri 03, 2009 10:32 am Posts: 1369 Location: New Rochelle, NY
I am working on a Zenith 6D311. The set came with a ballast tube, but the dial lamp did not work. After spending some time trying to find the source of why the pilot lamp did not work, I eventually came to the conclusion that I had one last idea. The two wires to the lamp were connected to the ballast tube. I had a spare ballast tube from another set and made the switch. The pilot lamp glowed nicely. How do I buy another ballast tube? The schematics for the Zenith 6D311 only states that it is a ballast tube. Can any type be used?
| Top |
Norm Leal
Post subject: Re: ballast tube replacement How is value determined? Posted: Apr Sat 14, 2012 4:18 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 28962 Location: Livermore, CA
Hi Ballast tube is a Zenith 100-70. It drops 49 volts @ 300 ma. There is a jumper between pin #3 and #4. Main resistance element between pin #3 and #7. Lamp tap between pin #7 and #8. This is a popular voltage drop. Ballasts like K49B would work but need to jump pins #3 and #4 at the socket. Check AES, www.tubesandmore.com or PTOP http://www.oldradioparts.com/2a2fl.txt
_________________ Norm
| Top |
decoflair
Post subject: Re: ballast tube replacement How is value determined? Posted: Apr Sat 14, 2012 5:08 pm |
| Top |
BikenSwim
Post subject: Re: ballast tube replacement How is value determined? Posted: Apr Mon 23, 2012 6:05 am |
Joined: Oct Wed 14, 2009 6:36 am Posts: 3031 Location: New York USA
AES has the T-URB-009-BT, they show the resistors in it. You would need to jumper pins 1&2.
| Top |
Dave Wise
Post subject: Re: ballast tube replacement How is value determined? Posted: Apr Tue 24, 2012 8:53 pm |
Joined: Feb Thu 08, 2007 12:36 am Posts: 1164 Location: Hillsboro, Oregon
Has anybody actually bought an used a URB-009? The web page is missing info, I asked AES, and they never answered.
Thanks, Dave Wise
| Top |
BikenSwim
Post subject: Re: ballast tube replacement How is value determined? Posted: Apr Tue 24, 2012 10:29 pm |
Dave, What info do you need? It shows which pins the resistors are connected to, I hope the diagram is correct, and it goes in an octal socket. Ohms Law shows that you need all of the resistance, so jumper pin 1 &2 in the socket. Don
| Top |
Dave Wise
Post subject: Re: ballast tube replacement How is value determined? Posted: Apr Tue 24, 2012 11:09 pm |
Sorry Don, I meant URB-010. It's the blank one, not URB-009. I mistook URB-009 for it. So my question is off-topic, but still: Does anyone have specs on URB-010?
Dave Wise
| Top |
BikenSwim
Post subject: Re: ballast tube replacement How is value determined? Posted: Apr Wed 25, 2012 3:16 pm |
Dave, The URB-010 is a mystery. Open a new topic for it, see what answers you get. It can still be ordered. Don
| Top |
Dave Wise
Post subject: Re: ballast tube replacement How is value determined? Posted: Apr Wed 25, 2012 5:35 pm |
True enough, and it's just a few bucks. Next order, I'll get one.
Dave Wise
| Top |
Who is online |
Users browsing this forum: No registered users and 4 guests |
