It is currently May Tue 21, 2013 7:24 am
 Post subject: new mica cap question
PostPosted: Apr Wed 18, 2012 11:20 pm
I bought some new 110pF caps that are marked like this: (3rd line down)
Cornell Dubilier
Mil-C-5
CM05FD111FO3.........THIS IS ON THE CAP
110pF 1% 500Volts
Radial Leads
Dipped Mica Capacitors
So what on the cap tells me it's 110pF?
 Post subject: Re: new mica cap question
PostPosted: Apr Thu 19, 2012 12:18 am
Here is the code, go to the data sheet.
http://part.aboutsemi.com/pdfview/corne ... 11fo3.html
PostPosted: Apr Thu 19, 2012 4:27 am
Cornell Dubilier
Mil-C-5
110pF 1% 500Volts
Radial Leads
The "111", meaning "11" times 10 to the "1" power, that is 11 * 10, which reduces to 110. Just like the resistor color code, except with numbers.
PostPosted: Apr Thu 19, 2012 9:17 pm
Thanks to all. I think that I'll carefully write 110 on the backs with permanent marker :wink: .
PostPosted: Apr Tue 24, 2012 8:59 pm
I recommend learning to interpret the code. This isn't going to be the last coded cap you'll see.
Dave Wise
Post New Topic Post Reply  [ 5 posts ]  Moderator: Peter Bertini
