It is currently May Thu 23, 2013 7:38 pm
 Post subject: What is this?
PostPosted: Apr Wed 18, 2012 1:28 pm
I found three of these in a box of assorted red drop caps I picked up. Can anybody ID it? The body color is a brighter green than the photo shows.
kb3wbb
My radio files free download page:
http://www.enter.net/~rocketeer/radio/radio2.html
 Post subject: Re: What is this?
PostPosted: Apr Wed 18, 2012 2:45 pm
what does a meter say
CAUTION: Im no expert
PostPosted: Apr Wed 18, 2012 3:02 pm
+1 (or maybe even an impedance bridge)
If I ignore the green thing, I think I see a metal film or metal oxide resistor with axial leads. The leads going into the green thing may go to a coil wound on the resistor.
"100%" on E-Bay is not IQ......
PostPosted: Apr Wed 18, 2012 3:07 pm
Larry,
Reed relay, SPST. The outside windings are the coil. The axial leads are the NO contacts.
You should be able to meter the coil resistance.
Pete
edit...
found this, similiar style:
http://www.ebay.com/itm/Dunco-Reed-Rela ... 0400030989
A long journey always begins with the words, "I think I know a shortcut."
PostPosted: Apr Wed 18, 2012 3:15 pm
At least I got "coil" right........;)
PostPosted: Apr Wed 18, 2012 4:37 pm
Thanks Peter.
kb3wbb
PostPosted: Apr Wed 18, 2012 11:17 pm
It's one of two things...... A trigger coil for Zenon discarge bulb or a reed relay.
PostPosted: Apr Mon 23, 2012 12:12 am
My guess is it's a reed relay. What resistance does the coil winding measure?
PostPosted: Apr Mon 23, 2012 1:53 am
144.1 ohms, 144.8 ohms, and 144.2 ohms for the three.
kb3wbb
PostPosted: Apr Mon 23, 2012 2:03 am
Measure from the top pin to the bottom pins, Whats the resistances? Then only measure the bottom 3 pins. Whats the resistances between them?
PostPosted: Apr Mon 23, 2012 3:02 am
The only leads showing resistance are the long pigtails (144 ohms).
kb3wbb
PostPosted: Apr Mon 23, 2012 4:36 am
I see 2 long leads. Above you state 3 leads. If all three leads have continuity, It's a trigger coil. If the two center leads have no continuity to any adjacent leads, then it's probabily a reed relay.
PostPosted: Apr Mon 23, 2012 2:59 pm
No, not three leads, three units. I have three of those doofunguses, as described in my original post.
kb3wbb
Post New Topic Post Reply  [ 13 posts ]  Moderator: Peter Bertini
Users browsing this forum: Don Cavey, Giulio Maiocco and 3 guests
