Page 1 of 1
[ 9 posts ] |
| Author |
tpwooton
Post subject: Speaker crossover- electrolytic polarity Posted: Apr Thu 26, 2012 4:24 pm |
Joined: Mar Sun 04, 2012 3:36 am Posts: 27 Location: Cape Cod, MA
Below is the schematic for my motorola (hope it shows up, I didn't clip it very well)- I'm replacing the 5 mfd cardboard electrolytic in the crossover circuit with a polarized 10 mfd 50 v electrolytic. The problem is I can't tell from the schematic exactly which way to wire them in. The other electrolytics in the schematic seem to indicate polarity, but here the symbol is just two straight parallel lines. I'm guessing that the hot end is coming from the E1 speaker (top right of schematic, middle speaker) and negative to the E2, but I'm not sure. I'm still learning and do most things "paint by number" as they say, but I got stumped here. Thanks for your help : )
| Top |
sofaslug
Post subject: Re: Speaker crossover- electrolytic polarity Posted: Apr Thu 26, 2012 5:18 pm |
| Moderator |
Joined: Jan Thu 01, 1970 1:00 am Posts: 13192 Location: Berkeley, CA 94709
AFAIK, audio crossover caps have to be non-polarized.
Bob
| Top |
35Z5
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 8655 Location: Chesapeake VA
Connect two 10mfd back to back to repl the NP cap...
| Top |
Rich, W3HWJ
Post subject: Re: Speaker crossover- electrolytic polarity Posted: Apr Thu 26, 2012 5:45 pm |
Joined: May Tue 30, 2006 4:46 pm Posts: 4809 Location: Santa Rosa, CA
Actually, I think you want to connect the two caps is series. Maybe that's what you meant by back-to-back? Quote: In this document Application Guide, Aluminum Electrolytic Capacitors bY Cornell Dubilier, a competent and respected capacitor manufacturer it says (on age 2.183 & 2.184)
If two, same-value, aluminum electrolytic capacitors are connected in series, back-to-back with the positive terminals or the negative terminals connected, the resulting single capacitor is a non-polar capacitor with half the capacitance.
The two capacitors rectify the applied voltage and act as if they had been bypassed by diodes.
When voltage is applied, the correct-polarity capacitor gets the full voltage.
In non-polar aluminum electrolytic capacitors and motor-start aluminum electrolytic capacitors a second anode foil substitutes for the cathode foil to achieve a non-polar capacitor in a single case.
| Top |
Chris108
Post subject: Re: Speaker crossover- electrolytic polarity Posted: Apr Thu 26, 2012 6:47 pm |
Joined: Jun Fri 19, 2009 6:34 pm Posts: 2676 Location: Long Island
You'll note the little "NP" below the capacitor symbol. This, and the schematic symbol (without a + and -) means the capacitor is a non-polarized electrolytic. An ordinary (polarized) electrolytic will not work properly here.
You can buy new non-polarized caps, or you can make one by connecting two ordinary capacitors in series back-to-back (both + terminals connected together, or both - terminals connected together) as 35Z5 suggests. Connecting capacitors in series reduces the overall capacity, so you have to start out with bigger capacitors. In this case, two 10-uF capacitors in series will give you 5-uF. Each should have a voltage rating equal to, or greater than that of the original cap.
Another way around this is to use a metalized polyproylene capacitor of the same ratings as the original. Since metalized film caps are inherently non-polarized, you get away from the whole issue. They also tend to do a better job of passing high frequencies, which may make the radio sound better.
_________________ "Hell, there are no rules here--we're trying to accomplish something!"
| Top |
Pbpix
Post subject: Re: Speaker crossover- electrolytic polarity Posted: Apr Thu 26, 2012 6:52 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 9160 Location: Haledon, NJ, usa
Rich, W3HWJ wrote: Actually, I think you want to connect the two caps is series. Maybe that's what you meant by back-to-back? Quote: In this document Application Guide, Aluminum Electrolytic Capacitors bY Cornell Dubilier, a competent and respected capacitor manufacturer it says (on age 2.183 & 2.184)
Rich What 35Z5 said is exactly correct: He needs a 5uf non polar... so he'll need to connect two 10uf polarized caps back to back. neg to neg or pos to pos. "BACK to BACK" means ... neg to neg -or- Pos to Pos That way you'll create a non-polarized cap of 1/2 the value.... same voltage rating. "In series" ... means pos to neg ..... then you STILL have a polarized cap... of 1/2 the value but double the voltage rating.
_________________ " To be a man, Be a non-conformist, Nothing is as sacred as integrity of your own mind." Emerson
| Top |
Rich, W3HWJ
Post subject: Re: Speaker crossover- electrolytic polarity Posted: Apr Thu 26, 2012 7:53 pm |
Quote: Connect two 10mfd back to back to repl the NP cap... I could interpret this to mean "connected in parallel, " with the neg of one connected to the positive of the other. I spent a lot of years in the semiconductor business. Back-to-back connection of SCRs was always in parallel, one going in each direction to make a complete AC switch.  Rich
| Top |
threeneurons
Post subject: Re: Speaker crossover- electrolytic polarity Posted: Apr Thu 26, 2012 8:08 pm |
| Member |
Joined: Jul Sun 17, 2011 1:11 am Posts: 1784 Location: Los Angeles
| Top |
tpwooton
Post subject: Re: Speaker crossover- electrolytic polarity Posted: Apr Thu 26, 2012 8:38 pm |
Okay, thanks for the info! I saw the "NP" and thought it meant "non-polarized", but didn't realize that this nixed the polarized caps completely. Will look into getting some non-polarized caps, and now I know for the future. Looking forward to hearing this console with all six "golden voices" firing up at the same time....
| Top |
Who is online |
Users browsing this forum: No registered users and 4 guests |
