It is currently Jun Wed 19, 2013 3:27 am
 Post subject: Doublet antenna? Also, vintage aftermarket loops?
PostPosted: May Wed 02, 2012 8:55 pm
I was looking at the antenna hook-up diagram for my 1936 Silvertone Model 1970A, and it looks like there are three wires (red, black, green) that can be hooked up in two different ways: either the black and red hooked to a cold-water pipe and the green to a long wire, or the black alone to a water-pipe ground and the red and green twisted together and attached to a "doublet antenna".
First off, exactly what is a doublet antenna, and what are the comparative advantages of a "doublet" versus a long wire?
Second, were there any after-market loop antennas made that would work well with this set, along the lines of a Zenith "Wave Magnet"? For that matter, how hard would it be to build a rotating loop to fit inside the cabinet, and how would I hook it up?
 Post subject: Re: Doublet antenna? Also, vintage aftermarket loops?
PostPosted: May Wed 02, 2012 11:39 pm
A doublet is a dipole. These were usually center-fed through twisted pair, sometimes with a matching transformer incorporated at the feed point and another transformer at the radio.
Advantage is lower noise pickup.
PostPosted: May Thu 03, 2012 1:03 am
Okay, now what about adding a loop to this set? Feasible, or should I just run a wire antenna and ground indoors if I want to avoid an outdoor antenna? I live with my parents (can't afford otherwise) so drilling holes in the walls for lead-ins is pretty much out of the question...
I have also heard of something called a Silvertone Allwave Antenna here (I believe this radio belongs to a forum member):
http://home.comcast.net/~skbrothers/site/?/page/Silvertone_4586_Console_Radio_%28est._1936%29/
Anybody know anything about this device?
Post New Topic Post Reply  [ 3 posts ]  Moderator: Peter Bertini
Users browsing this forum: Jack Shirley and 3 guests
