It is currently May Tue 21, 2013 4:47 pm
 Post subject: Electrolytic Capacitor question from a new guy.
PostPosted: May Sat 05, 2012 5:03 pm
Hello from Pittsburgh.
my name is brian and i am glad to be here on your site. I have started to really get into vintage record players and i have purchased two Steelman models both in very rough shape. i have started work on my little 3S8 model as it seems fairly simple. I am, however, having problems finding an Electrolytic capacitor I need. it is a 50/30 150volt unit. can anyone point me in the right direction?
 Post subject: Re: Electrolytic Capacitor question from a new guy.
PostPosted: May Sat 05, 2012 5:14 pm
You need to buy two discrete replacement capacitors. You can use a 47 mf to rreplace the 50 and a 33 mf to replace the 30, as these are modern values. Observe the polarity. The original has a common negative, and you will make it so by joining the negative wires of the new replacement capacitors together. Cut the old part out and discard it.
Make a list of everything you need to defray shipping charges.
Hobby friendly sources include:
www.justradios.com
www.jameco.com
PostPosted: May Sat 05, 2012 7:18 pm
Good advice.
I buy from Mouser or Digi-Key.
Use 160V capacitors.... better yet.... 200V. Line voltages are higher today than they were 50 or 60 years ago.
PostPosted: May Sat 05, 2012 9:22 pm
You can get one already made up from Bob http://www.radioantiques.com/supplies.html
PostPosted: May Sat 05, 2012 9:24 pm
Agreed in full.
:wink: Larry
PostPosted: May Sun 06, 2012 3:37 am
thanks to all of you for the quick responce. i'm going to place an order monday. this single tube amp looks easy enough to rebuild, I just dont know what the new component counterparts are. I will get a few pics of the unit up next week and any input you guys have to make it better is greatly appreciated!
PostPosted: May Sun 06, 2012 4:04 am
We will try to help as much as possible.
welcome to the forum :)
Post New Topic Post Reply  [ 7 posts ]  Moderator: Peter Bertini
Users browsing this forum: bassplyer9 and 1 guest
