It is currently May Thu 23, 2013 9:42 am
 Post subject: How do I test crc-808 tubes
PostPosted: May Sun 06, 2012 12:21 am
I have several CRC-808 tubes. I have the RCA data sheet with the pinout and specs. My tube tester I think will choke on the 7.5Volt 4.0 Amp filament requirement. I'd like to do a basic test so I can verify more than just filament continuity. I'm willing to make a jig.
Any help would be appreciated. :!:
Corby
 Post subject: Re: How do I test crc-808 tubes
PostPosted: May Sun 06, 2012 12:39 am
No way you want to screw up a typical tube tester. If you plan to actually use these old tubes, contact local Ham or radio clubs. Try the boatanchors forum here.
PostPosted: May Sun 06, 2012 12:56 am
+1
L
PostPosted: May Sun 06, 2012 12:58 am
Never mind.
A quick inspection shows them all bad! :(
Bits of gridwire floating around loose.
Bummer. :!:
Corby
PostPosted: May Sun 06, 2012 1:06 am
Corby
Broken wire you see may be filament. It breaks very easily in these tubes. Even though bad these tubes have value for display. How else can a person get a tennis ball tube for display?
PostPosted: May Sun 06, 2012 11:43 pm
Norm,
I have 8 of them. I can clearly see the grid coil move in some of them and see its missing bits. I think all but one show an open filament so the filaments could also be the bits I see loose.
I stuck all 8 as a lot onto Ebay as display tubes so hope someone will enjoy them!
Corby :)
Post New Topic Post Reply  [ 6 posts ]  Moderator: Peter Bertini
