Page 1 of 1
[ 13 posts ] |
| Author |
artdecoradios
Post subject: Question about German 12ax7 tubes Posted: May Wed 16, 2012 2:34 am |
Joined: Aug Thu 06, 2009 12:20 am Posts: 218 Location: Wheat Ridge, CO
Today, at a sale, I found 5 12ax7 tubes which say "Made in Germany" and also have the brand name "CEI" on them. Does anyone know anything about these tubes (who made them, etc.) There is no Telefunken "diamond" logo on the bottom and I wonder if they would have been made by Siemens. Thanks.
| Top |
renaissance.man
Post subject: Re: Question about German 12ax7 tubes Posted: May Wed 16, 2012 6:10 am |
| Member |
Joined: Dec Sun 03, 2006 8:16 pm Posts: 1190 Location: Pittsburgh PA
Pics?
_________________ Ed
| Top |
glasdave
Post subject: Re: Question about German 12ax7 tubes Posted: May Wed 16, 2012 7:53 am |
| Member |
Joined: Feb Tue 24, 2009 8:20 am Posts: 7727 Location: Aurora Colorado
_________________ I move the world just one step on...
| Top |
mescalero
Post subject: Re: Question about German 12ax7 tubes Posted: May Wed 16, 2012 11:46 am |
Joined: Feb Thu 24, 2011 1:29 am Posts: 2800 Location: Dallas, TX - in the city but with bobcats and coyotes
Is there an EIA code? That should tell you how they sound. Actually, it would let you know who made them.
_________________ In a triode, no one can hear you screen.
| Top |
BigBandsMan
Post subject: Re: Question about German 12ax7 tubes Posted: May Wed 16, 2012 12:15 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6030 Location: Raleigh NC USA
I have yet to witness a tube "sound" like anything to anyone who was not coached to "hear" it in advance.... Larry
_________________ It don't make a go if it ain't got that GLOW!
| Top |
Tubenut
Post subject: Re: Question about German 12ax7 tubes Posted: May Wed 16, 2012 6:13 pm |
Joined: Oct Sun 11, 2009 10:06 am Posts: 1441 Location: British Columbia
Betcha they have "heater flash"
| Top |
codefox
Post subject: Re: Question about German 12ax7 tubes Posted: May Wed 16, 2012 7:10 pm |
Nonsense galore! I'll tell you this, the Telefunken 12AX7 tubes of yore are very unlikely to be microphonic, likely to have matched emissions if it matters in the application, and are extremely hardy and dependable. It would be easy today to reproduce these classics provided there was a rational business reason to do so. Alas it is not the case.
| Top |
Tubenut
Post subject: Re: Question about German 12ax7 tubes Posted: May Wed 16, 2012 7:54 pm |
codefox wrote: Nonsense galore! I'll tell you this, the Telefunken 12AX7 tubes of yore are very unlikely to be microphonic, likely to have matched emissions if it matters in the application, and are extremely hardy and dependable. It would be easy today to reproduce these classics provided there was a rational business reason to do so. Alas it is not the case. Who said anything about microphonics or emission? The only nonsense is the inability to see that a bright spot in the heater is a sure weak point.
| Top |
BigBandsMan
Post subject: Re: Question about German 12ax7 tubes Posted: May Wed 16, 2012 8:03 pm |
| Member |
+1
L
| Top |
swanson
Post subject: Re: Question about German 12ax7 tubes Posted: May Wed 16, 2012 10:42 pm |
Look at the top of the tubes.If the glass has seams in it that look like a cross then it is probably made by siemens or valvo.Look for the acid etched codes near the bottom of the base. There are web sites you can go to that have charts to decode the numbers and symbols to find out who the manufacturer is.We really need to see some pictures to give you a definite answer as to who made it.It could also be a falsely branded eastern European tube. Regards, Swanson
| Top |
mescalero
Post subject: Re: Question about German 12ax7 tubes Posted: May Thu 17, 2012 2:01 pm |
"likely to have matched emissions if it matters in the application" - I fail to see how the tube manufacturer could know what applications would apply to so generic a tube. I'm not meaning to poke. I'm just observing. As for tubes with specific applications by design; I expect that, just like with ASICs today, those customers typically could (and did) pay for just about whatever they wanted. Telefunken's reliability is not in question as far as my opinion goes. Their prices today does seem to be out of line, but, whatever sells - sells. Back to the original question: The OP wanted to know manufacturer and the EIA codes should tell better than anything else. I probably should (and will) be chastised for making any reference to "sound - vs- brand." I rather derailed the thread. For that , I apologize. My fingers think faster than my thinker, sometimes. Well, out of sync, anyway.
| Top |
Jim Cross
Post subject: Re: Question about German 12ax7 tubes Posted: May Thu 17, 2012 7:41 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 653 Location: Orlando, FL, USA
The EIA code probably will not help. The supplier was allowed to provide their own code, so it does not have to be the code of the actual maker (eg the "922" code on International Servicemaster tubes, although International made nothing). Also, most foreign tubes do not have an EIA code on them from the factory.
CEI was a rebrander and rebranded and resold tubes made by anyone.
The only ways to positively identify decent tubes made in Germany....
Telefunken made in Germany will have the diamond impressed in the bottom of the glass as well as a pretty identifiable plate structure.
Seimens will usually have a Philips-type factory code that looks like a "does not equal" sign.
Valvo-made will have a "D" factory code. If really German, they are most likely to be RFT.
Jim Cross
| Top |
neutronic
Post subject: Re: Question about German 12ax7 tubes Posted: May Thu 17, 2012 9:24 pm |
Joined: Oct Fri 16, 2009 11:10 pm Posts: 173 Location: Bergen The Netherlands
Jim Cross wrote: The EIA code probably will not help. The supplier was allowed to provide their own code, so it does not have to be the code of the actual maker (eg the "922" code on International Servicemaster tubes, although International made nothing). Also, most foreign tubes do not have an EIA code on them from the factory.
Siemens will usually have a Philips-type factory code that looks like a "does not equal" sign.
Jim Cross More German factory codes Philips style: Telefunken capital font ¨T¨ upside down Tungsram capital font ¨L¨ upside down Loewe Opta code: II Jard N.
| Top |
