Page 1 of 1
[ 14 posts ] |
| Author |
dschulma
Post subject: Bumblebee Cap Value??? Posted: May Wed 30, 2012 8:16 pm |
Joined: Aug Wed 20, 2008 8:28 pm Posts: 2142 Location: Kansas City, MO
Can someone verify the value of this bumblebee for me (both in the photo are the same)? I see Brown, Gray, Orange, Gray, Blue. So, that would be 18,000pf, the blue band should be 600V, but what would the second gray band indicate...should be tolerance, but I don't see a tolerance value for gray??? Am I reading this wrong? Thanks in advance.
_________________ 73, David--WD0ERU, QCWA #35042
| Top |
dschulma
Post subject: Re: Bumblebee Cap Value??? Posted: May Wed 30, 2012 8:50 pm |
Or could the gray be black? 10,000 pf, +/- 20% @ 600V.
| Top |
Burnt Fingers
Post subject: Re: Bumblebee Cap Value??? Posted: May Wed 30, 2012 10:05 pm |
Joined: Oct Sat 20, 2007 3:36 am Posts: 13596 Location: New Hampshire
I read it as .015 with the gray being green.
What does the schematic say?
| Top |
Dave Wise
Post subject: Re: Bumblebee Cap Value??? Posted: May Wed 30, 2012 10:47 pm |
Joined: Feb Thu 08, 2007 12:36 am Posts: 1163 Location: Hillsboro, Oregon
Looks like a grayish black to me, making both caps .01/20% at 600V. Of course the proper color is "gone". Dave Wise
| Top |
FM Refugee
Post subject: Re: Bumblebee Cap Value??? Posted: May Thu 31, 2012 2:27 am |
| Member |
Joined: Sep Fri 07, 2007 2:21 am Posts: 1817 Location: Brunswick, ME 04011 (USA)
...another vote for .01µF 600V here...that black on black doesn't work so well...
| Top |
easyrider8
Post subject: Re: Bumblebee Cap Value??? Posted: May Thu 31, 2012 4:39 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6765 Location: Minnesota
| Top |
Big Harry
Post subject: Re: Bumblebee Cap Value??? Posted: May Thu 31, 2012 1:57 pm |
Joined: Nov Wed 07, 2007 12:44 am Posts: 1639 Location: Hawthorne, Ca
I say it is a .01/600v cap. Harry
| Top |
BigBandsMan
Post subject: Re: Bumblebee Cap Value??? Posted: May Thu 31, 2012 2:08 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6016 Location: Raleigh NC USA
Agreed. A LED flashlight often works wonders in vivifying color bands on resistors, caps etc. It might not work in this particular case, but then again, it may. Worth a trial.  Larry
_________________ It don't make a go if it ain't got that GLOW!
| Top |
dschulma
Post subject: Re: Bumblebee Cap Value??? Posted: May Thu 31, 2012 8:55 pm |
Thanks for the replies guys, after locating the schematic, it is .01 uf @600V.
| Top |
wazz
Post subject: Re: Bumblebee Cap Value??? Posted: Jun Sun 03, 2012 2:43 am |
| Member |
Joined: Jun Wed 08, 2011 2:33 am Posts: 2047 Location: Ohio
Well I assume you are gonna either figure out how to stuff a bumblebee or replace it? I have dug a bunch of unused ones out of my junk boxes around here lately and they all leak, some not a great deal, but some pretty badly for a tube circuit usage. I keep finding old vintage caps that are neat looking but are just junk now. I do have some Black Cats that all measure right for value and no noticeable leakage. As for bumblebee values, among others, if confused I just put them on the cap checker and then know for sure what they are.
| Top |
dschulma
Post subject: Re: Bumblebee Cap Value??? Posted: Jun Sun 03, 2012 4:26 am |
Will be replacing, definitely. Have no interest in restuffing one of these little gems!
| Top |
Tubenut
Post subject: Re: Bumblebee Cap Value??? Posted: Jun Sun 03, 2012 3:49 pm |
Joined: Oct Sun 11, 2009 10:06 am Posts: 1441 Location: British Columbia
They use the coding that most newer caps use.... 103= .01uF.....104= .1uF ..... 224= .22uF and so on. The last band is the Voltage ....Blue is 600V. The middle black band in the value is slightly "off black" to contrast the body color.
| Top |
noisebox
Post subject: Re: Bumblebee Cap Value??? Posted: Jun Mon 04, 2012 12:52 am |
Joined: Mar Mon 02, 2009 11:48 pm Posts: 2873 Location: 97381, USA
I just had my first encounter with bumble bees. I opted for tracing the cap on the schematic and working with the value listed.
| Top |
dschulma
Post subject: Re: Bumblebee Cap Value??? Posted: Jun Mon 04, 2012 2:32 am |
noisebox wrote: I just had my first encounter with bumble bees. I opted for tracing the cap on the schematic and working with the value listed. Yes, that's what I did and the cap value and the schematic value matched.
| Top |
Who is online |
Users browsing this forum: abraves and 5 guests |
