It is currently Apr Sun 22, 2018 7:32 am
 Post subject: Tumb of the unknown tube(s)
PostPosted: Jan Thu 05, 2017 9:38 pm
Hello all, hope you all had a great Christmas and wonderful new year.
Anyway, I have received a box of tube that have no white ink markings any more. I tried the breath test, and the freezer test. No luck.
Is there any way to tell what these tubes could be? by number codes on the base?
for example I have a Westinghouse Reliatron 337 5R09
I would love to find out what these are so I can test them and put them into use.
Thanks and God bless.
 Post subject: Re: Tumb of the unknown tube(s)
PostPosted: Jan Fri 06, 2017 12:59 am
Try a LED flashlight in a darkened room, preferred a LED light with a single LED...
PostPosted: Jan Fri 06, 2017 2:21 am
Post pictures.
PostPosted: Jan Fri 06, 2017 6:09 am
337 is Westinghouse's EIA number and 5R09 is likely 54-09 or similar... My example would be 1954 week 09, nothing to do with tube type...
PostPosted: Jan Sat 07, 2017 1:18 am
Well I tried the bright LED light in a dark room found out ONE of my tubes is a 35XXGT I still can not tell what the others are.
Any other ideas?
Would pictures help?
PostPosted: Jan Sat 07, 2017 2:36 am
Sounds weird but as a last resort often a rub on your nose or forehead will leave a light sheen of oil that combined with a flashlight will help identify. I had a box of around 50 tubes that were generally unreadable but managed to get about a quarter of them identified. Of course you need to know where the marking was originally or have a teenager with really oily skin. If that doesn't work, they make for great off-hand air rifle practice.
"The first speech censured, the first thought forbidden . . . chains us all irrevocably."
PostPosted: Jan Sat 07, 2017 8:16 am
funny you should mention the rifle practice I thought about that, but with the prices on e-bay that would be some expensive targets.
Thanks, mike j
PostPosted: Jan Sat 07, 2017 2:55 pm
Any other ideas?
Yes, if one know's what he's looking at it's easy tot tell if it's a audio output, rectifier etc... A 35xxGT is likely either a 35L6GT or my namesake...
PostPosted: Jan Sat 07, 2017 4:43 pm
I've seen this question many times over the years. The answers that stick in mind are try viewing through the glass from the other side, breathe on the tube, breathe on the tube after freezing it, rub it in your hair (prefer greasy), swab it with iodine.
George
PostPosted: Jan Tue 10, 2017 9:42 pm
Has anyone ever tried using a fluorescent blacklight to illuminate a wiped away tube number?
-Jeremy
Users browsing this forum: robert1 and 4 guests
