It is currently Feb Sun 18, 2018 7:19 pm
 Post subject: WD11 to 1LA4 adapters
PostPosted: Jan Sat 07, 2017 4:01 pm
I just received three WD11 to 1LA4 adapters for my Aeriola Sr. receiver and amplifier. They look well-made and have the 6.8 ohm resistor across the filament leads. I went with 1LA4 because I had 4 NOS tubes on hand and tests I read said they worked well. Hopefully this weekend I can try them. My only concern is that they could have been about an inch longer to make it easier to remove them.
ex nihilo nihil fit
 Post subject: Re: WD11 to 1LA4 adapters
PostPosted: Jan Sat 07, 2017 9:21 pm
They look very nice, I wonder why the designer didn't go with a 1LH4 instead as it is a true triode (At least in one section) and one wouldn't have to deal with the issues associated with various grids that aren't being used.
Caretaker of Portable Tube Radios
PostPosted: Jan Sat 07, 2017 9:28 pm
Sure do look nice. I've used 3D6's. They are low cost (at least they were) and don't need an added filament resistor.
James Fred (deceased) made me special adapters where the entire metal portion of 3D6 went inside. Only glass portion of the loctal tube showed.
PostPosted: Jan Sun 08, 2017 12:26 am
Where did you get them?
Russ
A place for everything, everything in it's place. I just don't remember where all those places are.
PostPosted: Jan Sun 08, 2017 3:41 am
Like this Norm??
Currently has a 1LE3 in it.
Phil
I've been doing so much for so long with so little I can now do anything with nothing!
PostPosted: Jan Sun 08, 2017 3:57 am
Russ
Looks like the ones on ebay I have seen
PostPosted: Jan Sun 08, 2017 4:08 am
Yep, the ones from China. I confirmed they had the filament resistors. I based my decision on this info: "After similar tests were done with 1Q5s, it was found that there was little
perceptible difference in the performance of 1A5s, 1Q5s and 1LA4s. In conclusion, I prefer the 1A5 or 1Q5 for a substitute. They are cheap and available and perform
very much like the WD11." 1A5 and 1LA4 are identical except for base.
http://www.antiquewireless.org/uploads/ ... the_wd.pdf
ex nihilo nihil fit
PostPosted: Jan Tue 10, 2017 3:56 pm
The initial test didn't go well. I'm using the ARBE-III so the voltages are correct. I'm using a long wire antenna- about 20 feet, no ground. Frost headphones are known to work. I can hear some clicking on the headphones, but no reception. I checked the coils and they all have continuity. The 1meg resistor measured 3.3meg so I bridged in a 1meg resistor. I may change the caps, but I doubt if they have a problem. Next I'll check the wiring on the adapters.
ex nihilo nihil fit
PostPosted: Jan Tue 10, 2017 4:25 pm
On early radios like the Aeriola Sr. A ground if of pivotal importance for good or any reception.
Users browsing this forum: Don Cavey, Mr. Detrola and 8 guests
