It is currently Apr Sun 22, 2018 12:11 am
 Post subject: Can anyone ID this early coil?
PostPosted: Jan Sun 08, 2017 10:22 pm
I know I've seen these around, and can't recall if this a spark gap xmitter part or what.
Any help is appreciated.
cheers
Want-Crosley Playboy 124 cabinet any cond
Stromberg 1A chassis
Big Hallicraftrz Spkr
KD2AZI
 Post subject: Re: Can anyone ID this early coil?
PostPosted: Jan Mon 09, 2017 10:05 pm
Looks like part of an RF transformer and could have been used on a spark transmitter to couple the output of the tank circuit to the antenna. Typically there would be two of these coils, with one mounted on a hinge so that the coupling between the two could be adjusted.
PostPosted: Jan Mon 09, 2017 11:56 pm
It's certainly an early transmitter coil, but one cannot identify it as definitely spark. It could have been used with a spark, arc, or an early tube transmitter for that matter.
PostPosted: Jan Tue 10, 2017 6:09 pm
I wonder what the inductance is. When I saw the picture my first thought was, "Wouldn't that make for a cool looking crystal set!"
― R. A. Heinlein
PostPosted: Jan Tue 10, 2017 7:58 pm
Sure. It is the outside coil of a Murdock oscillation transformer...
http://www.stonevintageradio.com/descri ... 0110185711
Norman
cron
